    Default RFC Mark IVA (Royal Flying Corps)
    I just pick up a RFC Mk IVA PW. Its missing the crown (onion shape) and stem. Any idea of the length of the stem?
ID:	339682   Click image for larger version.
ID:	339683   Click image for larger version.
    Mar 2008
    Gothenburg
    2,813
    Default Re: RFC Mark IVA (Royal Flying Corps) (By: Barry Armstrong)
    I think you need to find a stem that fits with the winding gear inside the watch and then cut it to length.
    6,768
    Hi Barry,
    You're also going to need a ratchet wheel, because yours has four teeth missing.
    Mar 2008
    Gothenburg
    2,813
    Default Re: RFC Mark IVA (Royal Flying Corps) (By: gmorse)
    Good catch Graham!
    Default Re: RFC Mark IVA (Royal Flying Corps) (By: Skutt50)
    Any idea of the movement maker?
    Quote Originally Posted by Barry Armstrong View Post
    That is a "Eterna" manufacture Barry, should be a Calibre 83 and around 19 Lignes size.
    Registered user. stewey's Avatar
    Dec 2012
    Oshawa, Ontario.
    967
    Default Re: RFC Mark IVA (Royal Flying Corps) (By: Bila)
    It's interesting to see the War Department mark complete with what is known as the "broad arrow" on the case-back.
    Dec 2012
    Oshawa, Ontario.
    967
    Default Re: RFC Mark IVA (Royal Flying Corps) (By: stewey)
    There is a little bit of information in this rather long article: scroll down to "Watches, Non-Luminous, Mark IVA."
    http://www.royalsignals.org.uk/photos/watch.htm
    Quote Originally Posted by gmorse View Post
    Hi Barry,
    Looks like 6 teeth Graham, and your are right, it definitely needs a ratchet wheel.
  1. Royal Flying Corps cockpit watch.....
    By PJQL in forum European & Other Pocket Watches
    Last Post: 11-27-2014, 02:15 AM
  2. Ball 999 Marking
    By GD1 in forum American Pocket Watches
    Last Post: 01-31-2006, 04:45 PM
  3. Royal Bonn mark: Where is it?
    By owen.or in forum Clocks General.
    Last Post: 07-22-2005, 12:57 AM
  4. Nice find today Rockford 21j gr 910 marked RG
    By Cary in forum American Pocket Watches
    Last Post: 06-30-2002, 02:37 AM
  5. 992 marked B&O RR
    By PJW in forum American Pocket Watches
    Last Post: 02-03-2002, 04:23 AM
