    Default Does anyone know what kind of hands are these and where to find one?
    first post. ive been looking for these sets of hands as mine are bent and missing original lume. i'm not even sure what they're called (sword hands maybe?). also.. can bent hands be straightened out or should i just look for a replacement? thanks for all the help!
ID:	338896Click image for larger version.
    Mar 2008
    Gothenburg
    2,798
    Default Re: Does anyone know what kind of hands are these and where to find one? (By: jrue)
    Welcome to the forum.
    Hands can be straightened but it depends on a) how bent they are and b) what result you are looking for.
    The watch in your picture does not look hard to fix, actually I can't even see the bends.
    I have no idea about your experience with watchmaking but if you are a beginner I would recommend you take the watch to a watchmaker to get the hands sorted out. He should also be able to polish the hands and to replace the lumination.
    Apr 2013
    Linköping, Sweden
    1,723
    Default Re: Does anyone know what kind of hands are these and where to find one? (By: Skutt50)
    Not sure if the ones in the pictures are the ones you have or if you are showing the type you are looking for.
    I believe the style is called "baton", or more specifically "luminous baton". The seconds hand is normally separate from hour and minute and you would have to look for it separately. Unless you manage to find a maker or movement specific set.
    Best of luck!
    Karl
    Apr 2013
    Linköping, Sweden
    1,723
    Default Re: Does anyone know what kind of hands are these and where to find one? (By: karlmansson)
    Cousins UK sells these as singles or paired as "Luminous, Swiss" in different variations. Have a look at their watch hands section. The orange lume is going to be hard to find though.
    19,918
    Watchlume.com has the orange lume.
    Apr 2013
    Linköping, Sweden
    1,723
    Default Re: Does anyone know what kind of hands are these and where to find one? (By: Kevin W.)
    Quote Originally Posted by Kevin W. View Post
    Cool! Good to know. I meant that finding those hands with orange lume is going to be hard though. Re-luming is tricky business if you're a rookie.
    19,918
    Yes it is tricky to re lume a watch hand, i would say its a art. I have tried a few, different results.
    Mar 2008
    Gothenburg
    2,798
    Kevin, which part do you find trickey?
    I can recommend Bergeon 5680 superluminova kit.
    I use it all the time and it is hard not to get a good result!
    I just mix luminova powder with some adhesive and smear out on the back of the watch hand with an oiler....... The only time I failed I had the mixture to thin....
    As for color it is hard to say what the paint looked at when new. I find that it often change with time.
  1. Does anyone know what this is ?
    By Bill Manders in forum American Pocket Watches
    Last Post: 12-19-2009, 10:28 AM
  2. Does anyone know what these are?
    By StephanG in forum Horological Tools
    Last Post: 12-01-2007, 05:19 PM
  3. Does anyone know the model of this Welch parlor clock?
    By DBPhelps in forum Clocks General.
    Last Post: 07-14-2007, 05:33 PM
  4. Does anyone know the maker of this piece?
    By fume happy in forum Clocks General.
    Last Post: 09-27-2005, 01:02 PM
  5. Anyone know what the original hands should look like?
    By Hank Grimmick in forum Wrist Watches
    Last Post: 01-04-2004, 02:56 PM
