    Registered user. ANDY YALE's Avatar
    Jun 2013
    Jersey City, NJ
    463
    Default Some Questions on a Waltham Grade 636
    This is a model 1908 that has some features that are new to me. First motor barrel I have worked on, but it was easy to figure out once I recognized what it was.
    However, I'm curious about this screw on the underside of the train bridge which apparently holds the escape wheel upper jewel setting in place. Not seen one before.
    Also would like to know if these two pieces are assembled together and put into the watch as a unit. The came out that way. The bottom piece that holds the castle gear and it's shaft is a mighty tight fit into the plate. I'm one step ahead of myself but forearmed is forewarned.
ID:	338691   Click image for larger version.
    Apr 2015
    Lincs, UK
    261
    Default Re: Some Questions on a Waltham Grade 636 (By: ANDY YALE)
    Andy, I am going through a learning curve right now with the 1908 as well having just serviced half-dozen grade 635 and up. For the winding shaft (second pic) I have found that it is easier to assemble/lube as a complete unit then pop it onto the main dial plate. I then put the barrel bridge temporarily in place to hold the shaft in position so I can turn the movement over and screw on the small disc that covers the idler gear and holds the shaft in position.
    As for the escape wheel jewel, is it a capped jewel setting? I would be be surprised to find one of those as well, especially on a 17J.
    Default Re: Some Questions on a Waltham Grade 636 (By: Mark UK)
    That should be a capped jewel. When you remove the retainer, both the hole and cap jewel will come out in that direction.
    Jun 2013
    Jersey City, NJ
    463
    Default Re: Some Questions on a Waltham Grade 636 (By: Dave Coatsworth)
    Yes, the jewel setting is different than the others - it has a high profile setting. Thanks, guys.
    Jun 2013
    Jersey City, NJ
    463
    Actually, that jewel is not capped. It's a single jewel, a hole jewel with a raised jewel setting. I guess it's screwed in from the bottom because the setting is too high to allow for screws on the top side.
  1. Newbie with some questions on Elgin
    By Drb007 in forum Wrist Watches
    Last Post: 05-22-2011, 02:12 AM
  2. question on a Waltham watch
    By watts in forum American Pocket Watches
    Last Post: 04-13-2010, 12:51 PM
  3. Question on a Waltham Sidewinder
    By Sean Mc. in forum American Pocket Watches
    Last Post: 01-05-2007, 10:54 PM
  4. American Pocket Watch Some questions about a Waltham ladies pocket watch
    By John Midgley in forum Watch Repair
    Last Post: 10-08-2006, 11:34 PM
  5. Question on a Waltham for beginner!
    By EricH in forum American Pocket Watches
    Last Post: 03-20-2002, 02:29 PM
