Goal: $300, Received: $225.00 (75%) Contribute Now
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
  1. #16
    Registered User gmorse's Avatar
    Jan 2011
    7,031
    Blog Entries
    Default Re: Demagnetizer - Spend Big Bucks or Little Bucks (By: dAz57)
    Hi dAz57,
    Quote Originally Posted by dAz57 View Post
    ...The Swiss service centre I worked in used a Greiner demagnetiser, thing looks like a mutant horseshoe set at 45° with a tickle lever on the front, it was very effective too, I believe those are quite pricey.
    Yes, over £830 in the UK.
    "Ut tensio, sic vis" - Robert Hooke
  2. #17
    Default Re: Demagnetizer - Spend Big Bucks or Little Bucks (By: musicguy)
    Quote Originally Posted by musicguy View Post
    Sorry for the dumb question, but do you only degauss parts of watches as
    you service it. Or can you degauss an entire watch?
    Rob
    I foolishly highly magnetized my 1924 Waltham wrist watch by wearing it while carrying a laptop bag that used a magnet to hold it closed. (The magnet was a couple of inches from the watch for a lengthy period of time.) The hairspring was so magnetized that the watch was running crazy fast. I demagnetized the entire watch without opening it up and its been running great ever since. I recommend a small compass to test for a magnetic field before and after to be sure you actually removed the magnetism.
    I've also removed the magnetism on a 18s pocket watch this way, but it was only slightly magnetized. I'm guessing how well that works depends on the strength of the demagnetizer and how heavy/thick the watch case is.
    -Barry
  3. #18
    Registered user.
    Apr 2015
    Lincs, UK
    268
    Default Re: Demagnetizer - Spend Big Bucks or Little Bucks (By: Time2Fish)
    Quote Originally Posted by Time2Fish View Post
    I will keep looking on ebay. No South Bend or Elimag demagnetizers presently listed. Don't think I want to pursue building my own. My hobbies take up 125% of my time right now. haha
    The two components took two minutes to buy; two minutes to unpack and 5 minutes to assemble. I can understand anyone wanting to buy and use quality tools but decades old coils coated in degrading varnish doesn't tick that box for me, especially when new components can be purchased so cheap.
  4. #19
    As I said personal preference, I used​ a coil type when I was an apprentice, I found it was a bit iffy, sometimes it would work, other times you had to demagnetise the item several times before it was clear, the Elma demagnetiser works first time, every time and it's fast.
    I don't know about other types but mine works great. It's the only one I'll probably ever need. If I ever do need a big one, I'll just build it myself.
    Robert
  5. #20
    Default Re: Demagnetizer - Spend Big Bucks or Little Bucks (By: Mark UK)
    Quote Originally Posted by Mark UK View Post
    No problem. If it needs it, I'll rewrap the coil. That's the main reason I bought the vintage South Bend, I figured it would be easier to rebuild than the newer ones.
    Robert
  6. #21
    Registered user.
    Jun 2013
    Toronto, CANADA
    39
    Default Re: Demagnetizer - Spend Big Bucks or Little Bucks (By: bearklaw)
    Quote Originally Posted by bearklaw View Post
    ... I recommend a small compass to test for a magnetic field before and after to be sure you actually removed the magnetism.
    Or use a mobile phone app like "Gauss Meter" for Android, which uses the sensor in the phone to detect magnetic field strength.
    - Robert
  7. #22
    Registered User musicguy's Avatar
    Jan 2017
    New York State
    742
    Default Re: Demagnetizer - Spend Big Bucks or Little Bucks (By: robmack)
    I used the phone app to test for magnetism, I'm not
    sure if it's accurate, but based on the results it
    seems that I should get a demagnetiser.
    And again, not to belabor the point, doing an entire watch
    will not hurt the watch even the hairspring etc?
    What do you think of these:
    http://www.ebay.com/itm/Demagnetizer...wAAOSw7NNT2S~-
    http://www.ebay.com/itm/INDUSTRIAL-M...MAAOSwhQhY0ta5
    http://www.ebay.com/itm/6-1-2-x-4-1-2-Plate-Demagnetizer-Tool-Dies-Cutters-Single-Phase-600W-/292060180825?hash=item440024b159:g:Tc8AAOSwRgJXkTe 2
    Rob
  8. #23
    Registered user.
    Apr 2015
    Lincs, UK
    268
    Rob I routinely demagnetise the hairspring as part of a service, and most of the time it is the only part that I do demagnetise as there is very little else in a nickel/brass watch movement that needs it. The occasional spring or bridge screw perhaps just to make them easier to handle. Most magnetised components will have no effect on function/timekeeping due to their size and location, the hairspring though is different due to each coil constantly and rapidly opening/closing which will induce 'eddy' currents in neighboring coils which in turn creates further magnetic fields which effects the performance of the balance.
  9. #24
    Rob
    The first one says it's for industrial use - NOT for watches.
    I think I would pass on all of the high powered ones.
    Robert
  10. #25
    Jan 2017
    New York State
    742
    Default Re: Demagnetizer - Spend Big Bucks or Little Bucks (By: Accutronica)
    Quote Originally Posted by Accutronica View Post
    Robert
    I did see that, it's that style I was asking about.
    Rob
  11. #26
    Again, your best value is going to be a vintage Elimag or similar 'instant' demagnetizer. L&R and Marshall also made them.
    A word of warning... There is a modern 'instant' one that is being sold for about $10. It's in a blue case and is fairly small. These do not work well and should be avoided.
  12. #27
    Registered user.
    Mar 2008
    Gothenburg
    2,854
    Default Re: Demagnetizer - Spend Big Bucks or Little Bucks (By: Dave Coatsworth)
    I agree with Dave that an instant demagnetizer is best.
    I got hold of a use Grainer demagnetizer some years back and it is great!
    One push of the handle and all magnetism is gone!
  13. #28
Name:	Screen Shot 2017-03-30 at 1.07.21 PM.png
ID:	338427Finally googled Elimag and saw what one looked like. I do remember seeing one on ebay without the Elimag nameplate so I want looking for it but the darn thing sold for less than $50. Darn!!!!
  14. #29
    Registered user.
    Dec 2011
    sydney Australia
    1,847
    Quote Originally Posted by Dave Coatsworth View Post
    Yes I bought one of those just to see what it was like, cheaply made, it's a flat version of a coil demagnetiser, you still need to draw the watch away after pressing the button, I'll stick to my Elma demagnetiser.
  15. #30
    Director Tim Orr's Avatar
    Sep 2008
    Boulder CO
    451
    Good evening, all!
    One advantage to the coil-type units: If you NEED to magnetize a tool, it's easy to do, then demagnetize it afterward. Just put the tool into the coil with the current off. Turn it on for a second or two, then turn it off again, without removing the tool. You'll find you've made a nice magnetic pickup tool that can be "erased" later by putting it back into the coil, turning the coil on, slowly withdrawing the tool a few feet away, and then shutting off the power.
    Best regards!
    Tim Orr
  1. Clock refinishing materials - store in Bucks County area ?
    By dougy in forum Clock Case Restoration and Repair.
    Last Post: 12-23-2008, 06:47 PM
  2. Car Clock? or Big Watch? Waltham
    By mpabrey1 in forum American Pocket Watches
    Last Post: 12-16-2008, 08:17 PM
  3. American Pocket Watch Making little clutch or lever springs.
    By Winterhawk in forum Watch Repair
    Last Post: 02-18-2007, 02:24 PM
  4. Old Foggies need not look.... Young bucks take notice
    By Dave Berghold in forum Wrist Watches
    Last Post: 10-17-2006, 08:42 PM
  5. Electrical Wristwatch holding or stabilizing all these little part!
    By Luca in forum Watch Repair
    Last Post: 06-08-2006, 07:55 AM
