Goal: $300, Received: $115.00 (38%) Contribute Now
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 59
  1. #31
    Registered user. Paul Raposo's Avatar
    Nov 2005
    Cambridge, ON Canada
    666
    Default Re: Picked up a Waltham Vanguard 1892! (By: AllanB)
    I lucked out and found a regulator for this watch. It's not the correct colour, but I didn't want to buy a movement and cannibalize it just for a regulator. I think I can have the arm gold plated if I decide to. I'm hoping it will fit, but the seller is a good guy and said I could return the parts if they don't work.
ID:	339527   Click image for larger version.
  2. #32
    Registered user.
    May 2014
    Nottingham , UK
    75
    Default Re: Picked up a Waltham Vanguard 1892! (By: Paul Raposo)
    Paul,
    Lucky you. Is the regulator assembly from another 1892 model or from another waltham model?
    The reason I ask is that I'm seeking a complete assembly for an 1892 vanguard 21j. I 'm also looking for a pallet fork for a 23j 1892 Vanguard. Like you I do not wish to purchase another movement just to canabalise it, that is unless it is already missing parts. Sourcing 1892 parts in the UK is a tad more difficult (and expensive!) than in USA.
    Allan
  3. #33
    Nov 2005
    666
    Hi Allan.
    The seller is clearing out watch parts and these two are from a pair of 1892s. I think the star regulator may be from a grade 845. The other one used to be an Ohlson regulator but was replaced with a whip spring.
    This seller also has two 1892 parts movements for sale. I'm going to PM you the link so you can see them.
  4. #34
    Registered user.
    May 2014
    Nottingham , UK
    75
    Paul,
    Thank you for bringing this to my attention. I have been successful and now have one of the parts (regulator arm) I need and in addition an 1892 "Riverside", all be it partial, movement to enjoy and perhaps in time restore to working condition.
    Allan
  5. #35
    Nov 2005
    666
    Very happy it worked out Allan
    I'm glad I didn't find these listings until the last day. It seems no one else noticed them either and we both got good deals.
  6. #36
    I have said this before. Be advised. In the approx. 25 year existence of the model 92, Waltham made multiple changes in design, specs, and overall parts changes. Just because you order a palate fork, doesn't mean it will work.
    The model 992's are a bear to fit parts. Just so you know, it is not easy.
    tom
  7. #37
    Registered user.
    Apr 2015
    Lincs, UK
    267
    Default Re: Picked up a Waltham Vanguard 1892! (By: Tom Huber)
    Quote Originally Posted by Tom Huber View Post
    Too true Tom, I have 3 Crescent St and an 845 all waiting on those elusive parts and sadly none of them interchangeable
  8. #38
    Nov 2005
    666
    Default Re: Picked up a Waltham Vanguard 1892! (By: Mark UK)
    Oh, that's disappointing to hear. Hopefully the regulator arm will work.
  9. #39
    Registered user.
    Apr 2015
    Lincs, UK
    267
    Quote Originally Posted by Paul Raposo View Post
    You should be safe with that Paul, but if you find out it is different then it is yet another part to add to the growing list of subtle changes that Waltham made. Differences that I have encountered seem to be confined to the balance shaft, escapement (wheel and pallet profiles and pinion lengths), lever set mechanism but I am sure that other differences have been noted.
  10. #40
    Nov 2005
    666
    Thanks for this info Mark. I'll post how it goes when the parts arrive.
  11. #41
    Registered user.
    May 2014
    Nottingham , UK
    75
    Thanks All,
    I had already read about the difficulty with parts interchangeability on this Waltham model. In trying to repair my 23j 1892 Vanguard the pallet fork from my 21j Vanguard and from my 845 have been tried with no sucess. One can but keep looking in the hope!!!
    The other partial 21 j movement I have just bought (witout pallet fork!!) will hopefully provide the last part for my 21j vanguard -- being the star regulator arm.
    Allan
  12. #42
    Nov 2005
    666
    When you get the watch finished Allan post some pics
  13. #43
    I've just restored a Waltham and decided to change a few parts. My donor movement was the same model and grade and year but it was a complete waste of time, none of them fitted. The hour wheel wouldn't even fit over the canon pinion! And I thought machine made watch parts were interchangable, He! He! I suppose over 120 years that many parts have been changed or modified by watch repairers that this is what makes it all interesting!
  14. #44
    Quote Originally Posted by AllanB View Post
    Thanks All,
    Allan
    Hi Allen, To replace your palette fork, it must come from a 23j Vanguard. the 23J fork has conical pivots to go in a cap jeweled pivot. The 845 and the 21J forks have open pivot jewels and have cylindrical pivots. they will not interchange.
    tom
  15. #45
    Registered User Jerry Treiman's Avatar
    Aug 2000
    Los Angeles, CA
    4,946
    With respect to fitting a new pallet fork or escape wheel to an 1892 model Waltham (and some other contemporary models), also keep in mind that Waltham changed the design slightly at one point, requiring that the pallet and escape wheel be matched if you are doing any switching or replacement.
Name:	pallet change.jpg
    Jerry Treiman, NAWCC member since 1971
    Charter member of Pocket Horology Chapter 174
  1. Picked up another Waltham 92
    By 8x57mauser in forum American Pocket Watches
    Last Post: 12-30-2016, 06:03 AM
  2. Picked up another Waltham 1857
    Last Post: 12-11-2016, 10:37 AM
  3. Waltham Vanguard 1892 model
    By wilsonpaule in forum American Pocket Watches
    Last Post: 04-27-2013, 02:13 PM
  4. Waltham Vanguard 1892 from 1903 regulator question?
    By Vsanzbajo in forum American Pocket Watches
    Last Post: 02-17-2012, 03:57 PM
  5. American Pocket Watch balance staff waltham vanguard 1892 model
    By stefanS in forum Watch Repair
    Last Post: 08-19-2010, 05:35 AM
