    Default great wheel clock springs
    I bought a couple of tall case great wheels, just to play with.
    They both need click springs.
    I'm trying to make those springs out of .40 main spring i had lying around.
    I could just buy the replacements at timesavers but thought it would be fun.
    Reasonable? asking for trouble?
    i collect antique clocks because i get all that extra time...
    5,355
    Default Re: great wheel clock springs (By: smike)
    Just to clarify. Are you talking 0.40 mm, and if so you can make them out of any spring steel you have on hand.
    Registered user. RJSoftware's Avatar
    Apr 2005
    Loxahatchee, Florida
    7,322
    Default Re: great wheel clock springs (By: David S)
    Sounds like fun.
    Are you going to do anything with them after you get the clicks to work?
    RJ
    The bitter the challenge, the juicy the conquest.
    Default Re: great wheel clock springs (By: RJSoftware)
    The click springs on mine are all brass.
    5,355
    Default Re: great wheel clock springs (By: novicetimekeeper)
    Smike, steel banding that is used to secure stuff to skids etc makes a nice source of spring steel. It comes in 0.015" and 0.020" and thicker. I asked my local industrial supply guy to save me a couple of feet. Nice stuff and for free.
    i just bought 'em because there's something about great wheels that makes me happy... not sure if i'm going to end up doing anything with them other than CCEUs (continuing clock education units).
    yes, i'm talking about using .40 mm mainspring, from a broken one i took out of a movement.
    i've already got the shapes roughed out and just need to hand file to make the little projections that stick/secure into the great wheel itself... worst case scenario i screw it up and have to start over... but i have plenty of stock to work with. 8-)
    Quote Originally Posted by David S View Post
    Smike, steel banding that is used to secure stuff to skids etc makes a nice source of spring steel. It comes in 0.015" and 0.020" and thicker. I asked my local industrial supply guy to save me a couple of feet. Nice stuff and for free.David
    cool... may have some in the garage somewhere in the 'you should probably clean this up sometime' pile.
    i'll see how the main spring works...
    Your tip is a day late & a dollar short. I threw out metal strapping 3 times in the last few weeks. I'll have more and save myself some next time.
    The man who knows how to make it work will always have a job, The man who knows why it makes it work will always be his boss.
    Default Re: great wheel clock springs (By: BLKBEARD)
    Quote Originally Posted by BLKBEARD View Post
    i know the feeling... "i'll never need THIS stuff"... uh huh 8-)
  1. Great wheel mantle clock
    By marylander in forum Clocks General.
    Last Post: 09-22-2014, 09:10 AM
  2. Banjo clock great wheel
    By Bruce Barnes in forum Clocks General.
    Last Post: 01-26-2009, 04:36 PM
  3. How to know when a clock spring is fully wound.
    By timepast in forum Clock Repair
    Last Post: 12-01-2006, 09:17 AM
  4. CLOCK SPRINGS
    By bob n in forum Clock Repair
    Last Post: 07-05-2006, 12:58 AM
  5. locking pin to secure rachet on great wheel
    By Donald P Bellamy in forum Clock Repair
    Last Post: 10-20-2003, 01:36 AM
