Goal: $300, Received: $80.00 (27%) Contribute Now
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: Bezel Removal
  1. #16
    Registered user. THTanner's Avatar
    Jul 2016
    Carson City, Nevada
    946
    Default Re: Bezel Removal (By: JHorner)
    You will need to remove the bezel, then the hands and the nut holding the movement to the dial. I have a commercial source for the I-QQA20-00 I showed above and for some other options depending on the length of the arbor that is needed for your clock that I can share with you in a PM if you like. I don't think an exact replacement for your movement is available so the mounting screw holes will probably not match and your hands may not fit on the replacement. You should be able to use the speaker in your clock, but you will most likely get a new speaker with a new movement.
    Quote Originally Posted by JHorner View Post
    I removed the two screws. The movement wouldn't budge, the nut on the face of the dial must be holding it firmly in place. There is another thin piece of wood, the same size as the movement itself, between the movement and the clock case.
    Thank you everyone for your comments.
    You miss 100% of the shots you don't take. - The Great One
  2. #17
    Nov 2002
    39,596
    Default Re: Bezel Removal (By: THTanner)
    Did you replace the batteries? Weak batteries will cause this problem.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  3. #18
    When you get the bezel off, take of the hands and see if it will work without them. Does it always stop when the hands are opposed to each other like that?
  4. #19
    On the hands issue, these clocks have a soft plastic hour hand cannon/shaft. If the hour hand is to tight, over time it will pinch the soft cannon and stop the minute hand! There is also a clutch (intetnal) that allows you to sync the chime dropoff from the back without moving the movement. A nice feature but it gives a lot of trouble. The plastic parts are tiny as the movement is a sub assemply to what you see and only about 1 1/4" square. Customers really like these movements but overall a pretty crappy movement in my experience. To many design flaws. I would expect Hermle to come back with a similar movement in the near future. Hopefully it will be a better design with better quality control ... I can dream can't I?
  5. #20
    Default Re: Bezel Removal (By: Fitzclan)
    Quote Originally Posted by Fitzclan View Post
    I don't think the bezel has to come off. It looks like the wood strips hold on a piece of plywood and I think the dial is attached to that. If you get that plywood out, I think the whole movement, dial and hands are attached. Should be easy to replace. Just my 2 cents.
    I like Fitz's idea. Remove the two battens and the entire mounting board should come out, dial and all.
    Is what I think.
  6. #21
    Jul 2016
    Carson City, Nevada
    946
    Default Re: Bezel Removal (By: bangster)
    If that can be done, you end up with the bezel, the glass, the hands, the nut and dial all out of the case. But you still have to remove the hands and the nut to remove the movement - if in fact it needs to be replaced - so you would still have to get the bezel off. Unless I am missing something about how this is put together??
    Quote Originally Posted by bangster View Post
    Is what I think.
  7. #22
    Quote Originally Posted by THTanner View Post
    It looks to me like the bezel is attached to the outer case, not to the mounting board. I think the board, with dial and movement, will come out leaving the bezel and glass in place.
  8. #23
    Jul 2016
    Carson City, Nevada
    946
    Possible - and would be great if that is how it was done. I don't think I have seen one where the mounting board and dial was mounted in the case with glued in pieces though. And I don't see any screws to remove the trim boards. But hard to see from the pics.
  9. #24
    Registered User wow's Avatar
    Jun 2008
    Pineville, La. (central La.)
    1,977
    Hey, Bang, if you look real close at the first photo, I think there is a brass nut behind the hour hand. I think the movement is mounted with that nut. If so, the bezel will have to come off in order to get to it.
    Wonder where the OP went. I'm curious.
    Will Walker (WOW)
  10. #25
    Nov 2002
    39,596
    Default Re: Bezel Removal (By: wow)
    Perhaps he found out that he only needed to replace the batteries
  11. #26
    Jul 2016
    Carson City, Nevada
    946
    Default Re: Bezel Removal (By: harold bain)
    Just "fixed" a cheaper version of a similar movement for a veteran who came in about an hour ago. He had one battery in the wrong direction. Luckily his movement had a diode to prevent damage. New batteries in the right direction, a cup of coffee, a fine chat for an hour and he is happy. I am sure it is just a money issue, but when they make the + and - sign for battery alignment really small and from black plastic down in a battery hole inside a clock case it can be hard to see which way to put them in.
    Quote Originally Posted by harold bain View Post
  12. #27
    No, still here. I did try several fresh batteries before posting here, so I don't think it is the batteries.
    I don't think that removing the mounting board can be done as being discussed. Those pieces that looked like wood strips are not strips, they are actually the back corners of the fluted quarter column and capital. Hopefully these pics show it a little better. The board the movement is mounted to continues up behind the curved top piece of the clock, and on the sides stops short of the 'strips' on the sides - which are actually the back corners of the columns, capital, and block that you see from the front.
    Thanks for the continued suggestions.
ID:	337232   Click image for larger version.
ID:	337233   Click image for larger version.
  13. #28
    Movement is attached to inside of the case. Dial/bezel attached to the outside. Bezel has to be pried off the dial. This can be difficult but once you get a little movement, continue around the bezel. At about the halfway around point they usually start to loosen.
  14. #29
    Default Re: Bezel Removal (By: Willie X)
    Well, so much for my suggestion.
  15. #30
    JH,
    Be sure to use the small screwdriver like a tiny crow bar, catching just the edge of the thin bezel. You can use a toothpick or a wood skewer as a fulcrum. Don't twist it, twisting will cause damage.
    Oh BTW, these movements won't work with Eveready batteries but this causes a no run condition, not an intermittent issue.
  1. Citizen Bezel Removal
    By PaulFaf in forum Wrist Watches
    Last Post: 08-26-2008, 01:29 AM
  2. Replies: 7
    Last Post: 11-01-2006, 12:55 AM
  3. Replies: 2
    Last Post: 10-31-2006, 07:17 AM
  4. Seth Thomas Dial/bezel removal
    By Seth Thomas Fan in forum Clock Repair
    Last Post: 04-21-2006, 11:13 PM
  5. Question About Caseback and Bezel Removers
    By Ivy Goodlett in forum Horological Tools
    Last Post: 02-13-2005, 12:06 PM
