Goal: $300, Received: $80.00 (27%) Contribute Now
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
    Nov 2012
    Denver, Colorado
    173
    Default Mobil 1™ 15W-50 full synthetic oil at Walmart. $6.95/qt.
    Would it be OK to oil the 1977 and 1979 Ridgeway grandmother clock Franz Hermle clock movements with it?
    Would the oil's additives be an issue?
    After using one drop in the clocks, would use the rest a few ounces at a time in the vehicles.
    Confucius say: "Man own clock know time. Own two, never sure."
    Default Re: Mobil 1™ 15W-50 full synthetic oil at Walmart. $6.95/qt. (By: Robert Gift)
    In a word, no. Use good quality synthetic clock oil.
    Motor oil is wrong for clocks for a variety of reasons - contains detergents(bad), is hydroscopic (designed to absorb water, very bad) and may not play well with copper alloys (also bad)
    Default Re: Mobil 1™ 15W-50 full synthetic oil at Walmart. $6.95/qt. (By: MrStretch)
    I guess I am in bad trouble. I have been using Mobil 1 for several years and as far as I can tell I have never had a come back due to using it. I will be eager to read any more comments.
    Nov 2012
    Denver, Colorado
    173
    Default Re: Mobil 1™ 15W-50 full synthetic additives (By: dickstorer)
    Quote Originally Posted by dickstorer View Post
    What viscosity do you use? (I did not know they made 15W-50.)
    Would be nice to see close-ups of the pivots and holes to discern if the Mobil 1™ additives have caused damage.
    Yes. I think it would be fine. The biggest knock with using Motor Oils, in my opinion, is that the formulas do change so you may not be able to buy something you've used in the past. You'll get a wide variety of opinions on lubrication on this Message Board. I've used Synthetic Mobil 1 0W-40 (for about 2 years) and Synthetic Castrol Edge Gold 10W-60 (over the last year) on our clocks. I've been very pleased with the results thus far. Admittedly, that's not a long time as far as clock maintenance goes. I've also used Ney Synthetic Clock Oil on some of our Grandfather Movements and have been disappointed by its performance on 1st & 2nd Wheel Pivots. It's too thin and it doesn't stay put very well...again...in my opinion.
    Registered User Hudson's Avatar
    Jul 2010
    Spicewood
    115
    Quote Originally Posted by Robert Gift View Post
    The 15w-50 would be just fine for the lower pivots, but you may want to consider a lighter grade for the uppermost ones.
    You will find many conflicting opinions and oil recommendations for clocks. I'm convinced that synthetic engine oils are just fine for clocks. You can find the opinions in previous threads on this board.
    Nov 2012
    Denver, Colorado
    173
    Default Re: Mobil 1™ 15W-50 full synthetic oil at Walmart. $6.95/qt. (By: Hudson)
    Quote Originally Posted by Hudson View Post
    The 15w-50 would be just fine for the lower pivots, but you may want to consider a lighter grade for the uppermost ones. ...
    The 0W-20 used in our vehicles could be used for the upper pivots. Is it too light to use everywhere?
    Why are VERGE PIVOTS not oiled?
    Why? What's the point?
    Nov 2012
    Denver, Colorado
    173
    Quote Originally Posted by MrStretch View Post
    Full synthetic. It's cheap compared to clock oils. I can get it. Haven't been able to get to clock shops while they're open.
    Leftover oil would be used in the vehicles.
    1,571
    It isn't clock oil. Sure I use some oils and greases for some things that aren't actually watch or clock oils but that is mainly because at times the real thing wasn't available. Clock and watch oils may be expensive to buy but the bottles take forever to empty. you could perhaps take some car oil off the dipstick of your car if you desperately needed some.
    Principal Administrator John Hubby's Avatar
    Sep 2000
    The Woodlands, TX
    11,102
    I have used full synthetic motor oils for over 25 years now with ZERO problems; I service in the order of 100 clocks per year and have had ZERO comebacks due to lubrication.
    I own three 400-Day clocks that I did some testing on starting in 1996 that I disassembled in 2001, 2006, and 2011 to check mainspring and pivot condition. One was lubed with Mobil 1 10W40 (mainspring) and 0W30 (pivots), one with Slick 50 HP (no longer available) for the mainspring and Etsyntha 5 (no longer available) for the pivots, and one with Slick 50 HP for mainspring and pivots.
    NONE of them have required re-lubrication of the mainsprings and all are still running (going on 21 years). At each check the mainsprings had a slightly wet appearance, no crud and no evidence of stickiness, thickening, or corrosion. The springs were reinserted in the barrels and placed back in service each time without adding any oil. I'll check them again later this year, didn't do that last year due to other priorities.
    >> Mobil 1 performance:
    No mainspring issues as noted. This clock required cleaning and relube of the pivots in 2011 (15 years service). The top end pivots had "dried out" although no evidence of wear and the clock was still running at the time. In this service I used Mobil 1 5W30 for the pivots, slightly higher viscosity based on recommendations from others who started using this oil in the same period I did.
    >> Slick 50 HP plus Etsyntha 5 performance:
    No mainspring issues as noted. This clock also had dry pivots but happened in 2006 after 10 years operation. I changed to Slick 50 HP and no problems since then, but I'll run out of my supply one of these days and it's no longer available. Etsyntha 5 has been replaced by Etsyntha 859, I have not used any of it so can't report.
    >> Slick 50 HP performance:
    No mainspring issues as noted. All pivots had visible oil present at each inspection although the oil is darkening with time. Will plan to clean and relube the pivots when I do the next inspection.
    Other observations include:
    >> Neither the Mobil 1 nor the Slick 50 HP had any problem with oil migration from any pivot holes.
    >> There is no metal discoloration with any of the lubes used in these tests, either around the pivot holes or on the pivots/arbors.
    A final comment:
    My interest in synthetic lubes started with finding that Nisshendo Watch Co. of Japan (Master TM) used synthetics for their mainspring lube from the earliest production in the 1950s. In the early 1960s they introduced 100-Day and 200-Day clocks that had sealed mainspring barrels that can't be opened without severe damage, evidently based on their confidence the mainsprings would never need servicing. I opened a couple of these in the late '90s just to check, and in those cases found the mainsprings to be in perfectly good condition, slightly wet with lubricant, and still with their original blued color after more than 40 years in service! I don't know what lube they used except that it has been analyzed and found to be 100% synthetic of about a 10W viscosity. My use of Slick 50 HP was based on their theory that the presence of colloidal Teflon would result in teflon being impregnated in the mainspring coil surfaces and result in much lower sliding friction. I carried out a series of tests in 1997-1998 using three 30-Day clocks and three mainspring lubes (Moebius mainspring grease, Mobil 1 10W40, and Slick 50 HP) that strongly supported that premise, with Slick 50 HP averaging about 23% longer run times than the Moebius grease and Mobil 1 giving 16% longer run times than the Moebius grease. That test is described in more detail in a post in this forum that was linked by Kurt.
    One other test I've carried out is to use Slick 50 One-Lube spray on mainsprings. My experience is that performance is excellent but no better or worse than Mobil 1 10W40. Being in a spray can makes it more convenient to use but it's a bit more expensive.
    Long story short: Since Slick 50 HP is no longer available, today I would choose Mobil 1 for my clock lube, 10W40 for mainsprings and 5W30 for pivots and never look back.
    EDIT: I've edited the comparative run times for the three lubes to conform with the actual results shown in the thread linked by Kurt, my memory was just about right but really need to use the source data.
    Registered User KurtinSA's Avatar
    Nov 2014
    San Antonio, TX
    1,526
    Default Re: Mobil 1™ 15W-50 full synthetic oil at Walmart. $6.95/qt. (By: John Hubby)
    John -
    Maybe this is the post?
    http://mb.nawcc.org/showthread.php?2...l=1#post175706
    Kurt
    Default Re: Mobil 1™ 15W-50 full synthetic oil at Walmart. $6.95/qt. (By: KurtinSA)
    I'm pretty sure that only the 1st number matters when using multi-grade/multi-viscosity motor oil in clocks. 5W-30 is 5w cold the 30 number is the high temp viscosity rating. a clock will never see temperatures required to change the viscosity. So 10-30, 10-40, 10-50 is all the same in this application. 5W-X, 10W-X, 15W-X, 20W-X would be your difference in this application.
    https://en.wikipedia.org/wiki/Motor_oil
    Scroll down to multi grade
    The man who knows how to make it work will always have a job, The man who knows why it makes it work will always be his boss.
    Yes, I would use the lighter viscosity oil beginning with the third wheel in the train on up to the Flys and Escape Wheel. Use the heavier viscosity on the first and second wheels. I alluded to that earlier but I should have stated it explicitly. Thanks Hudson for pointing that out.
    Regarding the Verge Pivots, we're getting into a whole 'nother area now. Some folks do oil the Verge Pivots. I always do. You'll definitely want to use a low viscosity there. I also apply a little oil to one of the pallets and let it distribute to the tips of the escape wheel's teeth.
    Most folks don't recommend oiling gravity powered levers and such, like Racks, Rack Hooks, Long Levers and such. The reason being that the oil tends to dry and gum up...that has been true of many of the older clock oils. Not so sure that it applies to the synthetics as much but you won't go wrong by leaving these surfaces clean and dry. Since you're not disassembling this movement you may want to be sure that these control levers move freely. If they don't you can carefully remove them and clean the pivot surfaces without disassembling the rest of the movement.
    Quote Originally Posted by BLKBEARD View Post
    I'm not sure if that fully applies to the modern multi-viscosity formulas BLKBEARD. What about the 0W-X oils? I use such a formula and it definitely has more viscosity at normal room temperature than does my Ney Synthetic Clock Oil. Just as clocks will not be operating at high temperatures, they won't be operating at freezing "Winter" temperatures either (Tower Clocks excluded). There are many different formulas out there and they change relatively rapidly. I do agree that the bottom number should serve as a good baseline. i just know that 0W-X is not "water" at room temps.
    John, thank you for taking the time to review your experiences with the use of these types of lubricants in Horology. I always get a little nervous recommending them because some folks hold very strong opinions against using motor oils in clocks.
  1. Synthetic oil
    By bcaclock in forum Clock Repair
    Last Post: 05-25-2012, 12:18 AM
  2. What property sets synthetic oil apart from other oils?
    By cazboy in forum Horological Misc
    Last Post: 04-17-2010, 10:44 PM
  3. Shelf life of synthetic oil
    By afremont in forum Watch Repair
    Last Post: 01-25-2010, 06:42 AM
  4. Synthetic, non Synthetic oil question.
    By Jeff C in forum Clock Repair
    Last Post: 03-27-2009, 08:48 AM
  5. Watche made to use no oil at all.
    By Greg Crockett in forum American Pocket Watches
    Last Post: 08-22-2002, 08:10 AM
