Goal: $300, Received: $125.00 (42%) Contribute Now
Thread: Worst repair?
    Default Worst repair?
    What's the worst repair you've come across? I've just finished a Waltham P S Bartlett, I'd noticed it had a basic regulator fitted whereas it should have had a Church patented starwheel reg, someone had obviously changed the balance cock out at some time as the number underneath did not match the serial number of the watch. Well I had a spare gold starwheel cock, luckily with the same matching damaskeening, so proceeded to change it.
    Then I noticed the screw that holds the hairspring to the cock was the wrong one. It had been replaced with one of the screws from the balance wheel rim! Not only that but when I tried to unscrew it I found it had been glued in! Well it was very enjoyable to get it all sorted out in the end. Do you have any tales of horror?
    Registered user. ANDY YALE's Avatar
    Jun 2013
    Jersey City, NJ
    463
    Default Re: Worst repair? (By: rolandantrobus)
    I think there is an existing thread called "Hall of Shame" or something similar which is chock full of horror stories. I mean blood and gore and splintered pallets.
    Registered user. Paul Raposo's Avatar
    Nov 2005
    Cambridge, ON Canada
    643
    Default Re: Worst repair? (By: ANDY YALE)
    I'm not a professional repairer but know enough to do very basic work. The last Elgin I had, the roller jewel was missing and someone had wrapped a piece of wire around the balance staff and was using the end of the wire as the roller jewel.
    Default Re: Worst repair? (By: Paul Raposo)
    These are horror stories today for collector's, but we must remember that these were items used daily for a person to know what time it was. In many cases, when a watch stopped and it was taken in for repair, the only thought in the owner's mind was getting it running and done as cheaply as possible. If changing a balance cock could be done cheaper, most of the time the watch owner would opt for that.
    One must be realistic. How many cobbled repairs are done daily to keep an automobile on the road.
    The same was done 100 years ago for watches.
    I have seen many oddball repair jobs on watches--some ingenious, others horrific.
    tom
    6,761
    Default Re: Worst repair? (By: Tom Huber)
    Hi Tom,
    How about these two repeater star wheel jumpers?
    And an ingenious way of securing a wobbly fusee click?
    Attached Thumbnails Attached Thumbnails IMG_0256.jpg   DSCF4158.jpg   DSCF4183.jpg
    Default Re: Worst repair? (By: gmorse)
    My favorite is a piece of wire looped around a case screw at one end and keeping tension on the click with the other. I've seen it a few times in beat up pocket watches.
  1. Worst Punch Repair Ever?
    By hookster in forum Clock Repair
    Last Post: 10-31-2014, 10:03 PM
  2. Worst repair experiences!
    By shutterbug in forum Clock Repair
    Last Post: 12-29-2013, 07:27 PM
  3. Reliable watch repair in Ontario, Canada--Or anywhere in Canada?
    By Paul Raposo in forum American Pocket Watches
    Last Post: 06-28-2013, 06:19 PM
  4. Watch repair in Detroit? Professional?!
    By J.S.Parker in forum American Pocket Watches
    Last Post: 09-17-2002, 05:00 PM
  5. When/or would you repair a dial?
    By Cary in forum American Pocket Watches
    Last Post: 03-27-2002, 06:33 AM
