    Registered user. TheTickTockDoc's Avatar
    Oct 2009
    New Port Richey, Florida USA
    399
    Default Eschle Singing Bird Bellow Repair
    Hello Friends: Well, not strictly horological in nature, many of the principals are the same. Here I have a bellows for a Eschle Singing Bird in a Cage. Although it looks pretty straight forward, I was wondering if anyone had any tips for repairing this. I have done a little Google research and didn't find much. I can replace the material like I do for cuckoo's, although I've seen some talk of using vinyl medical gloves for material. This looks like leather or a paper material. Any help or advice would be appreciated. Thanks, Rich
    Attached Thumbnails Attached Thumbnails IMG_7092.jpg   IMG_7093.jpg   IMG_7094.jpg   IMG_7095.jpg   IMG_7096.jpg
    12,991
    Default Re: Eschle Singing Bird Bellow Repair (By: TheTickTockDoc)
    The material is goat skin. It is available at most clock part suppliers.
    There are newer materials that will last longer, called Tyvek.
    The material that you can get from suppliers is of the proper thickness
    to work for bellows. Most other material is too thick. Most easily
    available tyvek it too thick, like house vapor cover or envelopes.
    Rubber glove material will not hold a fold well and is unlikely to work
    well. I doubt it will last as long as proper goat skin.
    Do a search on the MB here. There are several good post on doing bellows.
    To get the proper fold, when cutting the material, the open end should
    be square. Opening too much will cause the folds to interfere. Less
    than square will not fully expand.
    A relatively new US dollar bill has been said to work well. I've not
    tried this. I've used both goat skin and tyvek.
    Oct 2009
    399
    Default Re: Eschle Singing Bird Bellow Repair (By: Tinker Dwight)
    I generally have a supply of bellows material from Merritt's that I use for cuckoos. I'm sure it will work fine.....it's kind of a Tyvek material I believe.
    This link might be of interest..
    http://www.arcadetreasure.com/projec.../birdcage.html
    Ralph
    Apr 2006
    western PA.
    154
    Default Re: Eschle Singing Bird Bellow Repair (By: Ralph)
    YouTube has a series of videos on this restoration . "Griesbaum whistler bellows restoration" There are five or six videos . More than the bellows are all the valves inside to inspect or restore . Ignoring those valves makes bellows covering a waste of time .
  1. Singing Birds in Cage repair
    By shutterbug in forum Clock Repair
    Last Post: 05-12-2014, 11:43 PM
  2. Replies: 0
    Last Post: 08-29-2013, 11:21 AM
  3. German singing bird Bellows Help!
    By aleenfisk in forum Clock Repair
    Last Post: 08-22-2013, 07:32 AM
  4. Replies: 4
    Last Post: 12-26-2005, 08:33 AM
  5. Singing Bird Automata
    By griffco in forum Horological Misc
    Last Post: 12-08-2005, 11:03 AM
