Results 1 to 2 of 2
    Default Rat Rod PW/WR conversion-Big motor little case-how to wind & set??
    This is one of those hope to make something of it bay purchases. Woww a cheap Illinois!.
    Ok-the bad-2 cracked jewels & more-a bushing replacement for a jewel in the past it was down to 14....
    Got 2 in that I had in my spares pile & it is running albeit cranked over reg & a bit cranky on positions-but not bad. The original case was a dog & the watch is case set / wind. And its a sidewinder-watch conversion??. I machined a case I had a tad deeper/ wider to accept the behemoth-I love how it just barely fits. But now the actual hard part....
    I can use the small winder pictured to wind / set but to keep it in place & the click up down
    I don't think I could solder any new tube on this cheap Chinese case. I'm considering a short stem similar to the pictured-with a groove for a retainer clip & a small spring behind to push into the watch. A push me pull you setup.
    I'd wager someone has done this before. before I cob a solution any ideas??
ID:	336559Click image for larger version.
    Default Re: Rat Rod PW/WR conversion-Big motor little case-how to wind & set?? (By: Whereisitat)
    Moving to Watch Repair.
  1. How to "tune" chime rods
    By Vicki Gutierrez in forum Clock Repair
    Last Post: 09-07-2014, 06:59 PM
  2. Replies: 3
    Last Post: 03-19-2008, 07:45 PM
  3. How to lubercate electric motors
    By 70chevelless in forum Electric Horology
    Last Post: 03-06-2008, 02:25 AM
  4. How to salvage a chiming rod?
    By jz in forum Clock Repair
    Last Post: 04-06-2007, 04:04 PM
  5. How to take a little of the length of tight pivot.
    By 107WestStreet in forum Watch Repair
    Last Post: 05-19-2006, 12:46 PM
