Goal: $300, Received: $275.00 (92%) Contribute Now
Results 1 to 5 of 5
    Default 1931 Westclox Pocket Ben stem/crown removal
    First post on this forum. I have a 1931 Pocket Ben. The second hand keeps falling off, and it looks like I have to remove the movement to get at the hands. I have seen questions on this forum regarding removing the stem/crown, but these are all later movements very different from the one I have. Looking for some advice on how to do this.Click image for larger version.
ID:	336486. Not the greatest picture but I hope it helps.
    Thanks,
    Tim
    Registered user. stewey's Avatar
    Dec 2012
    Oshawa, Ontario.
    978
    Default Re: 1931 Westclox Pocket Ben stem/crown removal (By: kansastim)
    To get to the hands you have to remove the bezel (the front thing with the glass in it) not the entire movement. It probably just screws off.
    Registered User Jim Haney's Avatar
    Sep 2002
    Decatur, TN.
    4,996
    Default Re: 1931 Westclox Pocket Ben stem/crown removal (By: stewey)
    95% of all Dollar Watches have a snap on bezels, so you would use a blade like you did on the back bezel.
    This is a Repair question so The Moderator will most likely move it to that Forum.
    Jim Haney
    Default Re: 1931 Westclox Pocket Ben stem/crown removal (By: Jim Haney)
    Moving to Watch Repair
    Default Re: 1931 Westclox Pocket Ben stem/crown removal (By: Dave Coatsworth)
    As stated you get at the hands by removing the bezel. If you want to remove the stem for some other reason, try removing the large silver coloured screw from the mainspring plate. Reach in with a small hook and lift the retaining fork. Lots of times you can just wiggle the crown and stem and the fork will lift clear.
  1. Westclox Pocket Ben
    By sryan in forum American Pocket Watches
    Last Post: 07-10-2014, 11:46 AM
  2. Replies: 1
    Last Post: 02-28-2012, 04:09 PM
  3. Problem stem / crown removal
    By fly back in forum American Pocket Watches
    Last Post: 12-05-2011, 11:56 AM
  4. Electrical Wristwatch Balence spring for a westclox pocket ben
    By Joseph Wragg in forum Watch Repair
    Last Post: 04-05-2010, 07:52 PM
  5. Westclox Pocket Ben
    By MikeC in forum American Pocket Watches
    Last Post: 08-19-2005, 12:55 PM
