Goal: $300, Received: $360.00 (120%) Contribute Now
Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
Thread: Pendulum Wobble
  1. #31
    Default Re: Pendulum Wobble (By: shutterbug)
    Yes, can we see a picture. Generally one would expect the pendulum to hook onto a straight pin. If it hangs on a tapered pin perhaps only one supported at one point rather than across the length of the pin?
  2. #32
    Default Re: Pendulum Wobble (By: R. Croswell)
    Quote Originally Posted by R. Croswell View Post
    clockman230 -
    so far 2000+ words on the subject... including a couple of requests for pictures that would really help inform the discussion.
    i see ads on craigslist where the ad says 'clock for sale... wood'... with no photos... uh huh.
    do you not have a mobile phone you can use to take some photos or videos?
    these guys have sharp eyes... just sayin'/suggesting.
    smike
    i collect antique clocks because i get all that extra time...
  3. #33
    Default Re: Pendulum Wobble (By: clockman230@comcast.net)
    CM,
    Nothing should be "tight". The top of the suspension should be snug in its chops but free to move easily. Everything else should have plenty of freedom to move about. I often take the the complete pendulum assembly out and sight down it from the top. Everything should be as straight as an arrow. Also support the assembly at the hook, this will often show you that the joining point is not supported evenly. (I think this is what RC just mentioned). Often you will see a inward ot outward bow in the rod or stick. This alone can cause dishing.
    When I have one that refuses to do right, I often shorten the suspension spring a bit and lengthen the rating adjustment a like amount. This has somewhere around a 50:50 sucess rate.
  1. pendulum wobble
    By artpat in forum Clock Repair
    Last Post: 02-20-2008, 12:10 PM
  2. Pendulum wobble
    By ticktock in forum Clock Repair
    Last Post: 01-04-2007, 12:00 PM
  3. Thanks to all who helped on "Pendulum wobble"!
    By bobzyeruncle in forum Clock Repair
    Last Post: 04-17-2006, 12:34 PM
  4. Pendulum wobble
    Last Post: 01-03-2006, 12:35 PM
  5. Pendulum Wobble ?
    By Tom Kloss in forum Clock Repair
    Last Post: 11-18-2004, 12:24 PM
