    Default Vale & Rotherham pair cased Massey III
    I just received this 1831 Massey III with its pair cases having the distinctive mark of Vale & Rotherham registered in Birmingham 7/7/1830. A clean example in good working order - just needing a new crystal. The movement is not signed but it has some indications that it is Coventry finished. I suspect by Vale & Rotherham. The company are known to have been early adopters of the early detached levers including Massey variants. I found this on David Penney's site (here http://www.antiquewatchstore.com/arc...ntry-1826.html)
    "Vale & Rotherham, later becoming Rotherhams, the most important of the Coventry watchmaking firms that goes back to the middle of the 18th century with Samuel Vale who died in 1814. The firm were early manufacturers of the then new detached lever watches, with escapements by Massey, but continued to make verges into the 20th century, as well as being the first in England to take up American watchmaking ideas and tooling - a history that needs to be properly written up."
    I note that Ray (Omexa) describes an interesting watch signed by Vale & Rotherham on the barrel plate over a Liverpool finished movement, I was wondering what lever this watch has. - see here http://mb.nawcc.org/showthread.php?120854.
    John
ID:	336183   Click image for larger version.
ID:	336180   Click image for larger version.
ID:	336184   Click image for larger version.
ID:	336181   Click image for larger version.
    Default Re: Vale & Rotherham pair cased Massey III
    Hi John, I will have a look.
    I can't find it at the moment it is in hiding, it probably thinks that I am going to sell it. When I find it I will let you know. Regards Ray
    Default Re: Vale & Rotherham pair cased Massey III (By: John Matthews)
    Massey 3 John. Regards Ray
    Default Re: Vale & Rotherham pair cased Massey III (By: Omexa)
    Ray - Many thanks for checking. I went back to your original post - an interesting movement which produced some useful contributions. I don't know if you have had chance to dismantle it and check for any marks that might provide clues as to its Liverpool beginnings - beneath the dial perhaps.
    John
  1. Outer pair-case: leave it alone or fix it?
    By Lionel in forum American Pocket Watches
    Last Post: 04-02-2017, 01:00 PM
  2. Mid-18th century pair-case watch
    By Gan in forum American Pocket Watches
    Last Post: 04-21-2006, 06:22 PM
  3. Picture of Pair Case Movement Identification??
    By Tee Kay in forum American Pocket Watches
    Last Post: 02-22-2006, 12:09 AM
  4. Pair case maker Bothamley Boston
    By jagkar in forum American Pocket Watches
    Last Post: 07-04-2002, 07:54 PM
  5. Silver Pair Case Watch
    By L.Larson in forum American Pocket Watches
    Last Post: 11-12-2000, 02:45 AM
