Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Registered user.
    Dec 2011
    sydney Australia
    1,749
    Default Re: hex nut for faceplate on regula cuckoo one day movement (By: Chris D)
    Quote Originally Posted by Chris D View Post
    That could be taken the wrong way. I'll assume you were just mentioning that 'in case' anyone didn't already know that.
    Why?, There are people out there who don't know magnets only work on ferrous metals, I had one of them tried to get me to use a "gold" magnet while I was an apprentice, apparently he fell for that when he was an apprentice, the gold magnet was any handy lump of metal that was available.
    Anyhoo Regula have been using 3mm x 0.5pitch metric steel nuts on their movements like the 25 and 34 since the 70s, so a magnet will work in this case.
  2. #17
    Registered user.
    Dec 2011
    sydney Australia
    1,749
    Default Re: hex nut for faceplate on regula cuckoo one day movement (By: Tinker Dwight)
    I have been using a rubber work mat from HobbyKing, two sizes​, large 640mm X 400mm, small 395mm X 250mm, brands are trackstar and multistar, just do a search for work mat or rubber work mat
    https://hobbyking.com/en_us
    They have a large area in the middle and compartmented areas in the sides and back, those little bits won't roll away and disappear, they are cheap and easy to keep clean, great for clocks.
  3. #18
    Default Re: hex nut for faceplate on regula cuckoo one day movement (By: dAz57)
    Thanks guys. I ended up ordering an assortment package from Clock Works. I had gone to both Lowe's and Home Depot. They didn't carry anything that small. I'll keep you posted.
    And great idea on the felt.
    cs
  4. #19
    Registered user. THTanner's Avatar
    Jul 2016
    Carson City, Nevada
    506
    Default Re: hex nut for faceplate on regula cuckoo one day movement (By: dad1891)
    I use the small bubble wrap that is often in packages I receive with parts or clocks. With the little bubbles on the up side little parts fall into the grooves between the bubbles and go nowhere.
    Quote Originally Posted by dad1891 View Post
    THAT makes a lot of sense. Other benefits that you didn't mention is that the green color would be easy on the eyes and small parts would show up well. Now.........where in the heck do I find it?
    The purpose of a discussion is to learn something, not to prove who is right. Dalai Lama
  1. Replies: 17
    Last Post: 12-19-2011, 02:15 PM
  2. looking for info on Cashier case with venus movement
    By Bobbly in forum American Pocket Watches
    Last Post: 05-26-2006, 07:29 AM
  3. Need battery motor for Regula Cuckoo
    By Chris in forum Electric Horology
    Last Post: 12-20-2005, 12:40 PM
  4. Hand nuts for old cuckoo
    By james h rehrig in forum Clock Repair
    Last Post: 03-24-2005, 11:52 PM
  5. needing musoc box trip for one day cuckoo clock.
    By randy laham in forum Clock Repair
    Last Post: 02-16-2005, 12:41 AM
