Results 1 to 3 of 3
    Default Question about Hermle 1161-850AS
    I have a Sligh Grandfather clock with a Hermle movement 1161-850AS. It was make in 1986. When I look at the back there are to 90 deg levers on the top corners of the movement, does anyone know what they are? They can be moved to rest on each set of hammers for the chime and strike. Are they used for when the clock is moved?
    Thank you,
    Tom
    Default Re: Question about Hermle 1161-850AS (By: Driwash)
    Yes, but they are mainly for shipping.
    Default Re: Question about Hermle 1161-850AS (By: Willie X)
    Willie X, Thank you for the reply, sorry I did not reply sooner.
    Tom
  1. Hermle 1161-853 verge question.
    By rudiedog in forum Clock Repair
    Last Post: 12-02-2013, 08:29 PM
  2. Hermle 1161-853 Cable Drum question
    By edjal in forum Clock Repair
    Last Post: 04-01-2012, 03:29 PM
  3. Question about a Hermle 1051-850SK 85cm
    By Jeff C in forum Clock Repair
    Last Post: 03-22-2007, 06:01 PM
  4. New to Board -- Question about Hermle Movements
    By DavidMc in forum Clocks General.
    Last Post: 10-12-2006, 08:04 AM
  5. New to Board -- Question about Hermle Movements
    By DavidMc in forum Clock Repair
    Last Post: 10-12-2006, 06:55 AM
