Goal: $300, Received: $360.00 (120%) Contribute Now
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Registered user.
    Oct 2010
    12,978
    Default Re: double weight movement (By: novicetimekeeper)
    Quote Originally Posted by novicetimekeeper View Post
    oh I see, sorry I was still thinking about the movement. I think he said he had made a dial now, but we haven't seen any pictures yet.
    Ah yes, I read it fast and thought he needed a dial.
    I see now it was just a case.
  2. #17
    hi everybody, i am sorry by mistake i posted the wrong pix (one with 2-additional wheels on the Date Wheel) this design i had to cancel as i thought it won't be suitable. please see the pix attached with this message which is the final pix and also the dial. you will notice that i have kept the date wheel 'as is' one with the flag to move the date. this wheel has 60 teeth. the clock strikes every hour. keeps good time. Click image for larger version.
Name:	after restoration (28).jpg
ID:	336482Click image for larger version.
    regards,
    raj
  3. #18
ID:	336484Click image for larger version.
    hello everybody, the clock strikes every hour. the pix one which i had posted in the beginning with 2-additional wheels i have discarded and have kept the original date wheel with the 'flag' it has 60 teeth. i have attached the final pictures of the dial and the front part of the movement.
    regards,
    raj
  4. #19
    Default Re: double weight movement (By: info@antiquity.in)
    Looking good, is the dial engraved, you could silver the chapter rings.
    Why 60 teeth? They are usually either 31 or 62 to cover the months with 31 days.
    Nick, lots to learn, late starter.
  5. #20
    Registered user. ragobo's Avatar
    Apr 2015
    Barcelona
    189
    Hi Nick, would you counsel to silver the chapter ring on this occasion? for me it looks wonderful as it is!
    Really nice dial, hope someone could help you with some plans to build a period tall case. I think you did a marvelous work with that old movement
  6. #21
    Quote Originally Posted by ragobo View Post
    I would, yes. I would silver the chapter ring and the two subsidiaries, if the date ring is brass I'd dso that too. It sets off the numerals really well and makes the dial easier to read.
    EDIT> BTW as the dial plate is not arched you could make a flat top style with an arched mask and door
    https://www.the-saleroom.com/en-gb/a...9-a5fe012540ca
  7. #22
    Registered user. THTanner's Avatar
    Jul 2016
    Carson City, Nevada
    641
    Beautifully done
    Quote Originally Posted by info@antiquity.in View Post
    If you are not fired with enthusiasm, you will be fired with enthusiasm. Vince Lombardi
  8. #23
    Default Re: double weight movement (By: THTanner)
    You are very correct i am going to make a silver ch.ring and also the date ring in brass. Can you give me some idea of it's age?
  9. #24
    Silvered hopefully not silver. You may find that a better shape to the internal teeth on your date wheel might help, all of mine like that have teeth like shark fins.
    We did discuss date earlier, the same design of pillar and plates was used for over a century with little change but the detailing on your wheels suggest earlier in the period rather than later, I think late 18th early 19th century is as close as I could get.
  10. #25
    In the beginning all went like an experiment but now when the design is getting finalised i will replace the date wheel with brass and fig. etched on it with sharp teeth.
    regards,
    raj
  11. #26
    It seems like a very worthwhile experiment, it all looks very good.
  12. #27
    thanks
    regards,
    raj
  1. waterbury double-weight movement id and info?
    By smike in forum Clocks General.
    Last Post: 04-25-2016, 02:07 PM
  2. Gustav Becker double weight
    By vienna_sucker in forum Clocks General.
    Last Post: 08-26-2006, 08:06 AM
  3. Electric 2 Weight Movement
    By harold in forum Electric Horology
    Last Post: 02-21-2006, 07:11 AM
  4. 30-Hr Weight Movement Lifespan......
    By TomT in forum Clock Repair
    Last Post: 09-14-2004, 09:21 AM
  5. Need to find Gustav Becker double weight movement
    By Ralph in forum Clock Repair
    Last Post: 12-22-2003, 06:39 PM
