Goal: $300, Received: $225.00 (75%) Contribute Now
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Default Re: Cable Drum Plastic Guard Hermle 1161 (By: Tinker Dwight)
    You can likely get your center wheel out by removing the other two. The guard pin should screw out. Then wiggle it out one of the sides.
  2. #17
    Default Re: Cable Drum Plastic Guard Hermle 1161 (By: RRCos)
    The guard location pin is pressed in on these. You can work the cable drum out to the side, after removing the other drum/s, though. However, it's not that easy to get all the parts back in their proper position. Getting it back together is pretty easy, PROPERLY placing everything will take a while and a you will need a good movement stand.
  3. #18
    Registered user.
    Apr 2016
    Massachusetts
    Default Re: Cable Drum Plastic Guard Hermle 1161 (By: Willie X)
    Well, I oiled the movement and put it back in the case.. It's working fine, but I know that it eventually will fail. It is dated to 1985 and probably well past it's prime.
    I am not prepared to polish or repair bad pivots or replace bushings. When it fails, I will replace the movement with a new one.. then use this one to take apart and learn how to do those types of repairs.
  4. #19
    Quote Originally Posted by RRCos View Post
    That's a good plan. You'll have the identical new movement to refer to as you complete the repairs on the old one, and when you get it all fixed you could consider selling it on one of the auction sites.
  5. #20
    Default Re: Cable Drum Plastic Guard Hermle 1161 (By: shutterbug)
    Not all Hermle's had the removeable pins, as Willie already mentioned.
    I have had good success in regluing the broken cable protectors with Plasti Zap, once they've been cleaned with alcohol. Haven't had one break at the glued spot yet.
    So- how does the cable end up winding itself above the plastic, if it is placed below it to start
    Matthias in B.C.
    inhoffclocks.com
  6. #21
    Registered user.
    Apr 2016
    Massachusetts
    Default Re: Cable Drum Plastic Guard Hermle 1161 (By: matthiasi)
    Hello Mathias..
    The pin that holds the drum guard in place is missing (I did not see it at the bottom of the case). Without the pin, the guard spins freely along with the drum when the clock is wound. That's what caused the cable to wind on the outside of the guard. These do not appear to be removable pins.. they look like they were pressed into the plate.
  1. Replies: 5
    Last Post: 11-06-2015, 04:54 PM
  2. Hermle 1161-853 Cable Drum question
    By edjal in forum Clock Repair
    Last Post: 04-01-2012, 03:29 PM
  3. Replacement Hermle 1161-853A
    By P Gorman in forum Clocks General.
    Last Post: 02-28-2008, 12:21 AM
  4. Hermle 1161-853BS
    By kenknox in forum Clock Repair
    Last Post: 09-13-2006, 07:51 AM
  5. Hermle 1161-853BS problems
    By Greg R. in forum Clock Repair
    Last Post: 11-18-2004, 01:10 AM
