    Default Kroeber statue clock
    [ATTACH=CONFIG]334974[/ATTACh
    I please identify this kroner clock. Large statue looks like the statue of liberty except holding a harp not a book. Need name and what finish it was
    13,146
    Default Re: Kroner statue clock (By: nwo4rf)
    As we often have to say, we need to see the movement to
    have a chance.
    Also, we need a better quality picture of the dial.
    Pic of dial no pic of movement it is a standard krober 8 day time and strike movement
    Rest of the pics of the clockClick image for larger version.
ID:	335134 here are more pics
    Default Kroeber statue clock (By: nwo4rf)
    Just bought this clock a krober 8 day time and strike statue clock. The large statue on top looks like the statue of liberty two smaller statue on either side porcelain dial need to know name and what original finish wasClick image for larger version.
ID:	335160 IClick image for larger version.
ID:	335161 IClick image for larger version.
ID:	335162Click image for larger version.
ID:	335163Click image for larger version.
ID:	335164Click image for larger version.
    Default Re: Kroeber statue clock (By: nwo4rf)
    I've merged the two threads on this clock. Easier to follow the discussion that way.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
  1. Statue for the top of Kroeber Valencia clock
    By clockhoarder in forum Clocks General.
    Last Post: 08-07-2009, 09:13 PM
  2. Cleaning a New Haven statue clock
    By Weight Driven in forum Clock Case Restoration and Repair.
    Last Post: 05-03-2005, 11:16 PM
  3. Movement for a New Haven statue clock needed
    By Weight Driven in forum Clocks General.
    Last Post: 04-05-2005, 03:46 AM
  4. Kroeber China Clock Case Assembly
    By mlschlot in forum Clocks General.
    Last Post: 03-02-2005, 01:14 PM
  5. Statue Clock Info
    By MIKE NARDICK in forum Clocks General.
    Last Post: 11-07-2002, 05:01 AM
