    Default Cord Replacement - wires broken at motor
    There is little left of the wires on this 1934 Hammond clock. I need advice on making a safe and lasting repair.
    Attached Thumbnails Attached Thumbnails 20170301_113046.jpg   20170301_113153.jpg
    Default Re: Cord Replacement - wires broken at motor (By: semiretiredman)
    I never liked how they originally wired those things. To make a good repair, you'll have to carefully get back to the coil wires, make a connection with new wires, and secure it all again. I think they originally just used electrical tape to wrap around the coil after connection to keep things secure. I can't offer a better way, but wish I could!
    5,353
    Default Re: Cord Replacement - wires broken at motor (By: shutterbug)
    davefr over in the electric forum may be able to give some advice.
    12,637
    Default Re: Cord Replacement - wires broken at motor (By: David S)
    Get the back cover off as best you can. Try to not move the
    power wires around. You don't want to stress them at the coil.
    Once you have a clear shot at them, cut them from the coil.
    Usually there is a lug or something that they are soldered to.
    I recommend replacing them with a smaller power cord. Many of the
    cords that are used with computer power packs are good.
    If the lugs are loose be especially careful. You might even use
    a little epoxy to secure them.
    Do not try to remove the old soldered wire left from the power
    cord. There is no safe way to do this without skills most don't have.
    If you break the fine coil wire, it will be a more serious issue.
    ^^^Excellent advice.
    You do need to be extremely careful because the coil wires are about the thickness of a human hair and will break off very easily if stressed. It's best to do this under magnification.
    If all you have left is little stubs of the coil's magnet wire then don't try and solder on a thick power cord. Instead, attach some smaller wire like a 20-24 AWG stranded THHN to the coils magnet wires and then attach the power cord to the THHN. (less stress). You'll need to remove the varnish from the coil's magnet wires in order to solder to them. An Xacto knife will do this but you have to be extremely careful not to break off the wires.
    Heat shrink works well to insulate your splices.
    You'll likely need to rewrap the core of the coil to secure/insulate the wiring and provide some strain relief. I use 3M #27 glass cloth tape. (don't use common electricians tape).
    https://www.amazon.com/Corrosion-Res...ass+cloth+tape
    An even better solution is to slip a piece of large diameter heat shrink over the core of the coil and heat it until it completely compresses around the coil's core. 35-40mm 2:1 heat shrink should be about the right size.
    https://www.amazon.com/uxcell-Meters...+shrink+tubing
    Once your repair is complete secure the power cord to the motor frame with tie wraps for stress relief.
    Good luck because this type of repair is pretty tough and unforgiving!!
  1. American clock hammer wire broken at arbor
    By buksam in forum Clock Repair
    Last Post: 09-27-2009, 04:16 PM
  2. replacing a broken pallet stone
    By VergeMan in forum Watch Repair
    Last Post: 04-02-2007, 01:44 PM
  3. Replacing a broken regulator pin.
    By schweige in forum Watch Repair
    Last Post: 02-12-2007, 02:24 AM
  4. Replacing a broken mainspring.
    Last Post: 05-17-2005, 02:02 AM
  5. How do I replace a broken KW Pendant?
    By bchaps in forum American Pocket Watches
    Last Post: 08-03-2003, 11:12 PM
