Goal: $300, Received: $185.00 (62%) Contribute Now
    Registered user. gleber's Avatar
    Jun 2015
    Downingtown, Pennsylvania USA
    523
    Default To knob or not to knob...
    I just picked up a Jeromes & Darrow, which has a keyhole with escutcheon (which is missing and needs replacement). Initial thread here: http://mb.nawcc.org/showthread.php?1...-Jerome-Darrow
    There was a knob just below the keyhole. The photo shows the hole from the knob, which I removed for working on the door in general. The knob looks like a turned wooden knob, but I think it is actually ceramic.
    The question is, was the knob original, or does it have to go?
    Thanks,
    Tom
    1,467
    Default Re: To knob or not to knob... (By: gleber)
    I'd suggest that it is best to leave well alone. Not all clocks have a knob here but it is probably very useful and if not original then a clever addition by someone who cared for their work.
    Jun 2015
    523
    Quote Originally Posted by roughbarked View Post
    I'm not sure if it was the same person, but the protruding veneer chip in the top center in the photo is glued on rotated by 90 degrees. So, someone didn't care too much about their work... I have since fixed that (a near perfect fit when done correctly) and would prefer to restore it faithfully.
    It is nice to get your opinion of how to handle it, but I would also like to know if the knob is original or not regardless of how I proceed from here.
    Tom
    39,402
    I would guess the knob was added to make the door easier to open after the lock was removed. None of mine have anything like that.
    Jun 2015
    523
    Thanks Harold. The lock is still there, but the escutcheon is missing. In fact, when I picked it up, the door was locked and the key is missing, so it was sort of a mystery gift. I was hoping to find a stash of cash inside, but only found the weights and two winding keys, but no pendulum bob. I would have said they lost the key and added the knob, but then the knob would not do any good if the door was locked. So it is still sort of a mystery, but I tend to agree that the knob was a later addition.
    Tom
    1,467
    Quote Originally Posted by gleber View Post
    Tom
    Yes. All good points. The reseller may have locked the door with his own key to prevent it falling open?.
    Registered user. Sooth's Avatar
    Feb 2005
    Cornwall, Ontario, Canada
    3,583
    Default Re: To knob or not to knob... (By: roughbarked)
    I vote definitely no knob. I have a Daniel Pratt where someone had screwed-in a small brass knob (an old one) below the keyhole escutcheon, and it just really detracted from the overall look of the clock. I like to keep the keys in the lock with a tassel attached. The locks on these clocks are so simple that they can't easily malfunction or break, so ending up with a permanently locked door is very much unlikely to happen. I use the key every time I need to open the door. I find it much more satisfying.
    Jun 2015
    523
    Default Re: To knob or not to knob... (By: Sooth)
    Quote Originally Posted by Sooth View Post
    I agree that the knob does detract from the look, which is a reason I suspected it is not original. But, I did want to ask rather than assume. The consensus is building for no knob.
    Now the question is how to remove the evidence of it... I'm pretty good at matching color, but have more trouble matching the finish or sheen.
    Tom
  1. To wind or not to wind prior to shipment
    By purpledog in forum Clocks General.
    Last Post: 12-22-2005, 05:59 AM
  2. To Fusee or not to fosee
    By dumbo2 in forum Clock Repair
    Last Post: 09-29-2005, 06:31 PM
  3. To polish or not to polish?
    By timerider in forum Clock Repair
    Last Post: 09-10-2004, 11:15 PM
  4. To Clean or Not to Clean
    By Bob Lorenz in forum Clock Case Restoration and Repair.
    Last Post: 06-28-2004, 01:33 AM
  5. To be or not to be a Junghans?
    By OldCoot in forum Clocks General.
    Last Post: 10-29-2002, 01:58 PM
