Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Registered user. gleber's Avatar
    Jun 2015
    Downingtown, Pennsylvania USA
    509
    Blog Entries
    Default Re: Craigslist Cuckoo Clock (By: blindraccoon)
    I've seen all kinds of intricate carved settings including, wire, blades of grass, twigs with bark (carved from larger blocks of wood). It is amazing what some people can do.
    Tom
  2. #17
    Registered user.
    Oct 2010
    12,637
    Default Re: Craigslist Cuckoo Clock (By: gleber)
    I'm told the wood used on cuckoos are really good
    for carving. I do suppose one still has to watch the grain.
    I saw a video once of someone in the Black Forrest carving
    cuckoo parts.
    They just had some chisels, a mallet and a bench with a V shaped
    block to keep the wood from moving.
    In seconds they had a maple leaf done.
    My attempts at carving were never as good as yours, Tom.
  3. #18
    Registered User blindraccoon's Avatar
    Jun 2014
    San Francisco
    186
    Default Re: Craigslist Cuckoo Clock (By: Tinker Dwight)
    Not necessarily for you Tom, but along the lines of carving and just for fun, there's the chain saw carving (big saws and little saws) that can also be quite amazing.. a bear head carving in 4 minutes (elapsed time) https://youtu.be/S0uGmFRNOP0
  4. #19
    Registered User George Nelson's Avatar
    Oct 2007
    Tennessee
    460
    Yes, indeed... Sigh. If only I had that kind of talent...
    George
  5. #20
    Jun 2015
    509
    Blog Entries
    Quote Originally Posted by Tinker Dwight View Post
    cuckoo parts.
    Thanks Tinker. Yes, the wood selection is important. I use basswood, with a very fine grain, but I don't think that is normally used for cuckoo clocks. Most of my carving is done using a convex blade and dremel. I use a soldering iron with the tip filed to a knife's edge for the fine details like the feathers. The heat burns away a little of the wood to leave an open soft line instead of the slit you get if you just run a knife through. You can see the result here.
    I have not tried using chisels but would like to.
    Blindraccoon - sorry I seem to have highjacked your thread.
    Tom
  1. Cuckoo Clock Squeak
    By kirklox in forum Clock Repair
    Last Post: 01-24-2014, 10:53 PM
  2. Cuckoo clock movement question
    By mckpaul in forum Clock Repair
    Last Post: 03-25-2012, 09:51 PM
  3. cuckoo clock parts
    By randy laham in forum Clocks General.
    Last Post: 12-07-2005, 05:07 PM
  4. Cuckoo clock weight questions
    By eskmill in forum Clocks General.
    Last Post: 10-15-2005, 08:46 AM
  5. cuckoo clock large music box w/batt
    By randy laham in forum Clock Repair
    Last Post: 08-10-2005, 10:48 AM
