Goal: $300, Received: $80.00 (27%) Contribute Now
    Default Bulle - to oil or not to oil, this has helped me make my decision
    A Bulle just came in that is super original, including having its instructions on the inside of the back door.
    I've been oiling in limited places based on the belief that a clock movement is a clock movement - so why does would an electro-mechanical clock somehow not need oil?
    13,314
    Default Re: Bulle - to oil or not to oil, this has helped me make my decision (By: mopydick)
    Unlike a spring wound clock, there is no load on the pivots.
    The oil is just there to reduce friction of highly loaded pivots.
    Oil is just a dust and dirt attracter.
    I don't oil my electric clocks like the Kundo.
    Default Re: Bulle - to oil or not to oil, this has helped me make my decision (By: Tinker Dwight)
    Yes, I understand what you are saying - how EM clocks really don't have large torques within them versus a spring or weight driven clock.
    But the thought of metal to metal contact .... just gnawling at each other over time ... shivers down my spine ...
    Principal Administrator John Hubby's Avatar
    Sep 2000
    The Woodlands, TX
    11,004
    Quote Originally Posted by mopydick View Post
    Tinker (and the Bulle instruction) is completely correct. Never put oil on electric clocks of the Bulle, Brillie, ATO, or similar types that have little or no load on the gears. One problem particularly on Bulles is that any oil migration (vapor, actual oil) to the "Y" contact yoke arbor bearings can cause poor electrical continuity and erratic operation.
    13,314
    Default Re: Bulle - to oil or not to oil, this has helped me make my decision (By: John Hubby)
    Quote Originally Posted by John Hubby View Post
    Lubricating oils by their intent have high film strength. This is not true of
    all oils. Silicon oils have almost no film strength and are often used
    to both improve electrical contact and keep oxidizing air out.
  1. pallet arbor: To oil or Not to oil, that is the question.
    By FredWJensen in forum Watch Repair
    Last Post: 02-20-2009, 07:38 AM
  2. To oil or not to oil - that is the ?
    By R. Croswell in forum Clock Repair
    Last Post: 01-25-2008, 06:47 PM
  3. To Oil or Not to Oil
    By ticktock in forum Clock Repair
    Last Post: 10-28-2006, 04:49 PM
  4. To re-oil or not to re-oil...
    By bangster in forum Clock Repair
    Last Post: 07-08-2006, 12:37 PM
  5. To oil or not to oil Hermle 16 hammer movement.
    By RACRX in forum Clock Repair
    Last Post: 03-11-2005, 12:59 PM
