Goal: $300, Received: $275.00 (92%) Contribute Now
Results 1 to 14 of 14
    Registered user.
    Sep 2012
    Barnoldswick.Lancs
    259
    Default Vienna Clock case
    Please can anyone help. I am about to undertake a project on the Vienna case below The top & Bottom parts of the case is missing and I want to make the parts as near to the original design as possible but have no idea as to what they are. I wondered if anybody has a picture of the case in question. If I cannot get an answer i will invent my own design. Fenner
    P
    Registered user. roughbarked's Avatar
    Dec 2016
    Western NSW, Australia
    1,637
    Default Re: Vienna Clock case (By: Fenner)
    Quote Originally Posted by Fenner View Post
    P
    Your images appear broken.
    Apr 2002
    20,134
    Blog Entries
    Default Re: Vienna Clock case (By: roughbarked)
    I see no pictures posted.
    Registered user.
    Sep 2012
    Barnoldswick.Lancs
    259
    the pictures I put on are separate the bottom is a close up of the base of the case.
    Registered user.
    Sep 2012
    Barnoldswick.Lancs
    259
    Default Re: Vienna Clock case (By: Kevin W.)
    Kevin, I can see the pictures when I posted them and now in my posting so i cannot understand how you are not viewing them.
  6. #6
    I can't see them either - just two little squares at the bottom of your post.
    JTD
  7. #7
    Apr 2002
    20,134
    Blog Entries
    I see some square objects, i guess icons, but no pictures Fenner.
  8. #8
    Registered user.
    Sep 2012
    Barnoldswick.Lancs
    259
    This seems strange to me they are on the posting that I bring up they were inserted using the camera picture and they are both jpeg files. I will try again. These have been selected with the camera (add image) and uploaded and appears in my posting just before I submit.
ID:	332888   Click image for larger version.
  9. #9
    There were many variations of cases such as these. Unless you can find someone who has a catalog of the clock, and that means, knowing who the maker is, the best you can do is go to Timesavers.com or similar clock supply house and replicate as best you can the pieces you will need which appear to be the top crown and the bottom 3 finials. "Inventing your own design" might be the most practical course of action.
    Ron
  10. #10
    Registered user.
    Sep 2012
    Barnoldswick.Lancs
    259
    Default Re: Vienna Clock case (By: Rockin Ronnie)
    Thanks Ron.
  11. #11
    As you are in the UK, you could have a look at Meadow & Passmore's site (they are just outside Brighton). They have a selection of ready-made crowns for Vienna cases, and a large selection of finials as well. (m-p.co.uk is the website).
    Hope this helps.
    JTD
  12. #12
    Apr 2002
    20,134
    Blog Entries
    Default Re: Vienna Clock case (By: JTD)
    Hi Fenner i see your pictures now.
    Nice looking clock case too.
  13. #13
    To show you that it can be done effectively I received a Junghans "Vienna" style clock with only the crown. I made the left and right finial bases and the centre caps, added two decorative pins, purchased the finials that I thought best matched the case and stained them. This is the result.
    Ron
Name:	TS top crown work (5).jpg
  14. #14
    Registered user.
    Sep 2012
    Barnoldswick.Lancs
    259
    I agree Kevin I bet it took some making.
    - - - Updated - - -
    Thanks JTD I deal with M & P but never thought about checking them. will do
  1. Replies: 12
    Last Post: 08-13-2012, 04:04 PM
  2. Vienna Clock Case Help
    By Hezekiah in forum Clock Repair
    Last Post: 10-29-2010, 09:17 AM
  3. 'Tightening' cottage clock case
    By purpledog in forum Clock Case Restoration and Repair.
    Last Post: 12-27-2006, 12:59 AM
  4. Vienna Clock-Bob Rubbing Back Of Case-Not Working?
    By popeye in forum Clock Repair
    Last Post: 09-03-2006, 07:20 AM
  5. building a vienna-regulator clock case
    By Charlie Haywood in forum Clocks General.
    Last Post: 11-29-2002, 12:16 PM
