Results 1 to 2 of 2
    Nov 2010
    Hampshire, UK
    100
    Default Electronic circuit for Gents Chronopher III
    Evening folks,
    Does anyone have a copy of the electronic circuit for a Gents Chronopher II master clock please?
    It's the control board I'm after, but both boards would be useful.
    Many thanks if someone can help.
    Default Re: Electronic circuit for Gents Chronopher III (By: dennishoy)
    A while ago I've purchased a Gent's Chronopher III model XC 408 here in the Netherlands, I do not know how this clock got here but it might have been imported here (one of the few)
    The masterclock including the 2 slave clock have been working fine for about 1 year.
    It took quite a few days to have the slaves synchronised with the masterclock and to have the system running well. It eventually lost time: clock took around 70 minutes to complete a real minute so the system was running way too slow.
    But again after a few days fiddling around, the system started working fine till a few weeks ago when one of the slave was half an hour behind: adjusted the slave manually but shortly afterwards the clock kept behind as well.
    Powering OFF/ON, switching advance/normal, disconnecting batteries etc.etc. did not make any difference.
    Looking on the internet there is very little information about these clocks, let alone the manual.
    I was able to find some info about an auction 3 years ago offering a lot containing complete manual and wiring diagram of this type of clock. But the auction ended a year before I got my clock.
    Did you, in teh mean time, manage to get some more information e.g. wiring diagram/service manual?
    Regards
  1. Correct Voltage for Gents Pulsynetic Master Clock
    By Lincolnhill in forum Electric Horology
    Last Post: 03-10-2017, 04:09 PM
  2. Replies: 0
    Last Post: 01-16-2017, 03:52 PM
  3. Mechanical Wristwatch Repair Second Whell For IWC Pallweber III
    By watch-cbr in forum Watch Repair
    Last Post: 01-15-2013, 01:43 PM
  4. American Pocket Watch Help needed for Howard Series III
    By dweiss17 in forum Watch Repair
    Last Post: 06-26-2010, 11:34 AM
