Goal: $300, Received: $280.00 (94%) Contribute Now
Results 1 to 2 of 2
    Default Searching the Message Board using Google
    To do a Google search of the message board, append this to your Google search string:
    site:mb.nawcc.org
    Examples
    brass mainspring site:mb.nawcc.org
    cleaning watch crystals site:mb.nawcc.org
    best clock oil site:mb.nawcc.org
    remove battery corrosion site:mb.nawcc.org
    19,798
    Default Re: Searching the Message Board using Google (By: bangster)
    Thanks Bang i do this often, much faster way to search than the search feature on the web site.
  1. Re: Using the Message Board Search Engine
    By poppyboy in forum MB User Help & Comments; Policy Questions
    Last Post: 07-01-2008, 10:22 AM
  2. Re: Using the Message Board Search Engine
  3. Using the Message Board Search Engine
    By Jeff Hamilton in forum MB User Help & Comments; Policy Questions
    Last Post: 12-04-2007, 12:05 PM
  4. Using the message board and Google
    Last Post: 04-24-2007, 02:27 PM
