Goal: $300, Received: $350.00 (117%) Contribute Now
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Smile Re: Show and tell your 5star Vanguard (By: Mark UK)
    Quote Originally Posted by Mark UK View Post
    ... The price point of USD71.50 in those ads got me running to google. The exchange rate at that time would have been around 2.8 Dollars to the Pound so that would have had a price tag of £25 (or more) over here in the UK which would have been the best part of a months wages in the early 50's for those in skilled employment - ...
    Mark:
    I don't have any wage data on hand for the 1950s to compare with your numbers. The best I can do is the December 1922 report (below) which shows the average monthly wage for a railroad worker to be $141.13. Since that includes laborers and other unskilled workers, I'd estimate that the monthly wages for those railroaders whose positions required them to carry a railroad watch to be in excess of $150.
    A few years later, the mail order price for a 23-jewel Vanguard watch fitted with a wind indicator in a 20 year case was $65, about a week and a half's wages. For those in Canada, 1922 prices are available (keep in mind that those prices are in Canadian dollars - I have no idea what the exchange rate was).
    Kent
    That guy down in Georgia
  2. #17
    Registered User doug sinclair's Avatar
    Aug 2000
    Calgary, Alberta
    14,368
    Blog Entries
    Default Re: Show and tell your 5star Vanguard (By: Kent)
    I don't remember where I read it, but my impression was that engineers were paid on the basis of tonnage, and mileage. If the train wasn't rolling, they weren't paid. Probably similar for firemen, brakemen, and conductors. As an aside, in Canada in 1957, the price of a 992B was $195.00.
  3. #18
    Smile Re: Show and tell your 5star Vanguard (By: doug sinclair)
    None of the wage reports I've seen for U.S. railroaders mention tonnage, but I've only got a small sampling, mostly from the 1890s.
    As for the cost of a 992B, it was a lot cheaper from T. Eaton in 1953.
    Kent
  4. #19
    Jul 2009
    Kentucky
    2,725
    I'm rather partial to '92 model Vanguards with serial numbers lower than ~7.5 million. These have-to me-the most interesting demaskeen patterns.
    I especially like watches from the first two runs. They are designated in the ledgers as 17j, but a lot of them were upjeweled to 21j and marked "21 Ruby Jewels."
    Here are a couple from those runs
  5. #20
    Registered user.
    Apr 2015
    Lincs, UK
    255
    Default Re: Show and tell your 5star Vanguard (By: ben_hutcherson)
    Quote Originally Posted by ben_hutcherson View Post
    ...a lot of them were upjeweled to 21j and marked "21 Ruby Jewels."
    Nice examples Ben! What also caught my attention about the model 92 is that there are the earlier "21 Jewels" with capped escape lever/wheel, and later there are "21 Jewels" with jewelled barrel.
    Here is a model 1899 19J from 1900, OF pendant set, s/n 9545062. If I look up the database it comes back as 19J Riverside. If I search the database it suggests the first run of OF 19J wasn't until the 11mill s/n. I haven't yet stripped this one down to see if all numbers match but the damask is convincing, as is the diamond end stone. I can only assume that there was a short run of 19J earlier than suggested. The case is a Dennison 25yr filled, the dial is plain and appears to be hand painted.
  6. #21
    Technical Admin Tom McIntyre's Avatar
    Aug 2000
    Boston. MA USA
    18,774
    Blog Entries
    10
    Default Re: Show and tell your 5star Vanguard (By: Mark UK)
    Serial numbers above 7.55 million contain watches that were grouped to reduce the size of the listing and only provide information about parts replacement. i.e. the grade, jewel count, etc. is not accurate but the replacement parts are.
    The new site for Waltham serial number lookup provides the ability to look at the original input documents for any serial run. http://nawccinfo.nawcc.org. That landing page will change in the near future to show other NAWCC member material in addition to the Waltham serial numbers.
    Tom McIntyre Click me.
    If you don't learn to laugh at trouble,
    you won't have anything to laugh at when you're old.
    Will Rogers
  7. #22
    Registered user.
    Apr 2015
    Lincs, UK
    255
    Default Re: Show and tell your 5star Vanguard (By: Tom McIntyre)
    Tom, the pdf of the original input documents have my Vanguard down as a run of 19J OF Riversides. If my watch is correct then it will be from an early run of 19J OF Vanguards as yet not recorded anywhere. It would have had to have been a small run as the s/n range for the Riverside run was only 100.
  8. #23
    Here's three of my Vanguards that I particularly like.
    A 19J Demi-hunter in a Dennison G/F case. One of 500 made in three runs. This one is from the last run, S/N 20001351.
    This one is a 23J Vanguard with winding indicator S/N 25344351 cased at the factory in a green G/F case.
    This is a 23J, 1892 Model S/N 12080436 open faced movement in an unusual Dubois demi-hunter 14K solid gold case with engraved numerals filled with pale blue enamel that winds at the 12 o'clock position.
    Attached Thumbnails Attached Thumbnails DSCF0198.JPG   DSCF0202.JPG   DSCF0203.JPG   DSCF0200.JPG   DSCF0194.JPG
  9. #24
    Mar 2011
    CehNehDeh
    321
    Default Re: Show and tell your 5star Vanguard (By: doug sinclair)
    Quote Originally Posted by doug sinclair View Post
    Doug, this is Canadian info but the USA was very similar, running trades employees in thru freight service (Enginemen, Firemen, Conductors & Brakemen) were paid in a mileage basis.
    Initial terminal time, make up train, air test, etc., was paid at an hourly rate of 12 1/2 miles per hour.
    Upon departure you went from the hourly rate to straight running for the length of the subdivision and were paid only subdivision miles regardless of running time to the final terminal.
    The rate per mile remained the same.
    When arriving at the final terminal you would revert to the hourly rate, yard train, power to shop, until going off duty.
    When this system came into being trains moved much slower than today and it was calculated that it took 8 hours to travel 100 miles which is where the 12 1/2 mph figure (8 X 12 1/2 = 100) came from.
    So when it all shook out, 2 hour delay at each end = 50 miles plus 132 subdivision miles = 182 miles
    Return trip, lets just use 182 again = 364 for the round trip.
    Enginemen and Firemen were required to make 3800 miles per month (Conductors & Brakemen, 4300) so after 11 trips using an average of 350 miles per trip a Hoghead would have made 3850 miles.
    At that point he would go "off for miles" with a 50 mile bank toward next month and would go back on the board at midnight on his mileage date and begin his month over again.
    Regarding pay for tonnage, in some cases there was a very small increase in the rate paid per mile for various tonnage increments.
    Later there were increments for train length.
  10. #25
    Default Re: Show and tell your 5star Vanguard (By: onsite)
    HI there,
    I noted this thread quite some time ago, but just found some of my pictures recently, so here are some of my favorite Vanguards.
    Bill
    Attached Thumbnails Attached Thumbnails 2 003.jpg   2 006.jpg   19j vanguard 1892 002.jpg   19j vanguard 1892 004.jpg   crts 001.jpg
    crts 003.jpg   Vanguard Mdl 92 PS Ser 7002653 001.jpg   Vanguard Mdl 92 PS Ser 7002653 005.jpg   Waltham WI 003 [].jpg   Waltham WI 005 [].jpg
  11. #26
    Registered user.
    Mar 2010
    Georgia
    427
    Thought I would post a couple of mine. It is hard to pick favorites from the ones I have.
    Attached Thumbnails Attached Thumbnails DSC_0063.jpg   DSC_0059a.jpg   DSC_0070-001.jpg   DSC_0075.jpg
  12. #27
    Default Re: Show and tell your 5star Vanguard (By: luvsthetick)
    Another of my "faves" this time in a salesmans display case
    Attached Thumbnails Attached Thumbnails $_32 (1).jpg   $_32 (7).jpg   $_32 (5).jpg
  13. #28
    Dec 2009
    Boulder, CO Foothills
    3,155
    I have identical movement appearance to preceding movement 18150979 with 20066808 23j Montgmery rr dial and balance diamond cap. Was it a standard 1915 feature for the 23j Vanguard 16s ? I notice similar diamond cap in 16s 19j here from about 1900. artbissell
  1. Roskopf, show and tell.
    By Omexa in forum European & Other Pocket Watches
    Last Post: 05-10-2016, 10:59 PM
  2. Ladies anf Gentleman please show your appreiciation
    By SrWilson in forum Clocks General.
    Last Post: 08-30-2006, 06:14 AM
  3. Want to attend a watch show and sale.
    By fuzzuki in forum Wrist Watches
    Last Post: 12-08-2005, 11:34 PM
  4. Waltham Vanguard and Hamilton 974 Identification
    By Reinburg in forum American Pocket Watches
    Last Post: 08-02-2003, 12:14 PM
  5. Check out this eBay Santa Fe Special and tell me what you think...
    By railman in forum American Pocket Watches
    Last Post: 08-12-2002, 03:15 PM
