Goal: $300, Received: $20.00 (7%) Contribute Now
Page 1 of 4 1234 LastLast
Results 1 to 15 of 57
    Registered User musicguy's Avatar
    Jan 2017
    New York State
    847
    Default Watch you wear daily
    RE: Watch you wear regularly that you don't worry about getting damaged(figuratively)
    People are always posting photos of really nice high end watches, or
    beautiful gold watch cases and new acquisitions, watches that their great grandfather owned ect.
    I would like to see what people use as their daily
    wear watch. One that sometimes gets bumped around in your pocket, and you are using it as a
    watch (that you count on) on a dally basis.
    I have a 1903 18s Elgin 17j in a mismatched Oresliver case that has hairlines in the dial.
    I have regulated it to be very accurate and I use it as a daily wear
    watch.
    Default Re: Watch you wear daily (By: musicguy)
    I use a Waltham half hunter that I rescued a few years ago. It needed loads doing to it, case springs, new dial, mainspring etc but I got it fixed and regulated and now use it regulaly and it never lets me down and is super accurate.
ID:	330895   Click image for larger version.
ID:	330896   Click image for larger version.
    Jan 2017
    New York State
    847
    Default Re: Watch you wear daily (By: rolandantrobus)
    Nice!
    My favorite daily carry is a 19-jewel Bunn that I bought as a movement and cased in a display case.
    Default Re: Watch you wear daily (By: Dave Coatsworth)
    Generally, these days it's one of these guys:
    Though, I confess, it's most often the 478, because I just got it back from service (it had a cracked jewel) and I replaced the bent case I got it in with the same model case in excellent condition!
  6. #6
    Default Re: Watch you wear daily (By: GeneJockey)
    Any of these... although any 14s-16s that can readily be repaired or replaced will do, if it happens to be the first one to jump into my hand.
  7. #7
    Jan 2017
    New York State
    847
    Default Re: Watch you wear daily (By: topspin)
    Very nice. One of them must "jump into your hand" as you say first?
    Do you leave the tags on?
  8. #8
    Registered User Jerry Treiman's Avatar
    Aug 2000
    Los Angeles, CA
    5,032
    Quote Originally Posted by musicguy View Post
    RE: Watch you wear regularly that you don't worry about getting damaged(figuratively) ...
    I don't shy away from wearing a nice watch, but I do take care of it. My daily watch these days is a slim Waltham Colonial-A Riverside in a plain-polished gold case. I always wear pants with a watch pocket (or else I don't carry a watch), the pocket never has anything besides the watch in it and I keep it on a secure chain. I do select a watch for daily wear that is easily repairable in case the worst happens.
    Jerry Treiman, NAWCC member since 1971
    Charter member of Pocket Horology Chapter 174
  9. #9
    Mine is a Elgin 18s 11j 1889 Model 5 that I just acquired. It's also my only 18s. It's running about 20 seconds slow/day. I'll see how well it runs after I service it. First I'll have to practice on a Waltham 16s 15j 1897 Model 1888 movement that I bought. It should be here in a day or so.
    I also just acquired this cute little Elgin 3/0 7j 1920 Model 2. It runs but I'm not going to run it much till after I service it. I wound it up a little for the photos.
ID:	330981   Click image for larger version.
ID:	330982   Click image for larger version.
ID:	330983   Click image for larger version.
ID:	330984   Click image for larger version.
  10. #10
    Default Re: Watch you wear daily (By: Accutronica)
    I usually carry this G M Wheeler, but for special occasions and church I carry the H H Taylor.
ID:	331020   Click image for larger version.
ID:	331015   Click image for larger version.
ID:	331016   Click image for larger version.
ID:	331017   Click image for larger version.
ID:	331019   Click image for larger version.
  11. #11
    Jan 2017
    New York State
    847
    Default Re: Watch you wear daily (By: watchtinker)
    Very nice Elgin's from watchtinker, Accutronica and GeneJockey
    Love the 18's GM's and HH's and BW's (16s)
  12. #12
    Sep 2013
    St. Paul, MN
    112
    Sorry for the cross post (whole story here: http://mb.nawcc.org/showthread.php?1...ouple-new-16-s), but these are now in the active use rotation as of today. 1919 Hamilton 974 and 1916 pendant-set Hampden Wm McKinley model 5, both size 16.
  13. #13
    Apr 2002
    20,158
    Blog Entries
    Default Re: Watch you wear daily (By: TJ Cornish)
    Great watches everyone nice to see what people carry.
    This has been my carry watch the last 3 weeks Paillard , antimagnetic watch co.
  14. #14
    Registered user. 8x57mauser's Avatar
    Sep 2016
    Quincy, Massachusetts
    277
    Default Re: Watch you wear daily (By: Kevin W.)
    I have two, an 1857 P.S. Bartlett made 1866 and an English fuse Thomas Taylor, Manchester made 1835.
ID:	331079   Click image for larger version.
ID:	331078   Click image for larger version.
ID:	331077   Click image for larger version.
ID:	331076   Click image for larger version.
ID:	331074   Click image for larger version.
ID:	331073   Click image for larger version.
ID:	331072   Click image for larger version.
ID:	331071   Click image for larger version.
  15. #15
    I live at a distance of 5,000 miles away from New York but an american pocket watch is carried in my pocket every day. This Bunn Special is with me in the last months.
ID:	331063Click image for larger version.
    Many greetings to all from Athens Greece.
    Yiannis
    De omnibus dubitandum
  1. The most expensive watch you wear (was Nardin Freak)
    By Tom McIntyre in forum Wrist Watches
    Last Post: 08-28-2017, 02:53 PM
  2. What watch are you wearing today?
    By doug sinclair in forum Wrist Watches
    Last Post: 10-30-2013, 01:26 PM
  3. Is there any American pocket watch you would consider it a daily watch?
    By nomorewatch in forum American Pocket Watches
    Last Post: 10-19-2012, 08:38 PM
  4. Do you wear gloves when handling clocks?
    By Robert Gary in forum Clock Repair
    Last Post: 09-25-2005, 10:33 AM
  5. Watches to wear with pearl bracelets
    By bluewind in forum Wrist Watches
    Last Post: 10-29-2003, 11:14 PM
