Results 1 to 12 of 12
    Registered User JDCKent's Avatar
    Jul 2011
    Ellensburg, Washington, USA
    77
    Default Regency Lancet Twin Fusee Bracket Clock (Reid & Auld)
    Purchased this Regency period bracket clock at auction last year. After spending some time in the shop, it is now home and running beautifully. It turns out that there is a repeating function in the movement, and upon further inspection discovered that the original hole on the side of the case for pull cord had been filled. Anyway are a few new photos of the clock that I thought I'd go ahead and share.
    Default Re: Regency Lancet Twin Fusee Bracket Clock (Reid & Auld) (By: JDCKent)
    The bit of engraving on the backplate is nice, this seems to have continued longer with Scottish made clocks,
    Moderator leeinv66's Avatar
    Mar 2005
    Launceston Tasmania
    7,438
    Default Re: Regency Lancet Twin Fusee Bracket Clock (Reid & Auld) (By: novicetimekeeper)
    Beautiful clock! Clean and simple lines and not overly embellished. Just the way I like them.
    Cheers
    Peter R Lee: AKA (Pee-Tah) from Australia
    Jul 2011
    77
    Default Re: Regency Lancet Twin Fusee Bracket Clock (Reid & Auld) (By: leeinv66)
    Thanks! Apparently it needs a little more help still, because of a runaway strike train at the 1 o'clock position. Don't know for sure what the heck is not catching and stopping it. I'll have to remove the brick of a movement again and closely observe the mechanism to figure out what's going on.
    I would remove your "repeat" cord...and see if that fixes it.
    Ralph
    Jul 2011
    77
    Default Re: Regency Lancet Twin Fusee Bracket Clock (Reid & Auld) (By: Ralph)
    The clock has been doing this since before adding the cord, so it shouldn't be anything related to that. Seemed to strike and stop at the right number when it was out of the case, so thought it was fine. Put it back in the case, and when 1am came along it was right back it. I've switch it over to silent mode for now, until I have time to take it back out fiddle with it. I'll probably find a little better material for the cord itself, and replace it the next time I work on it. Most that I've come across online have that function, including these examples by Handley & Moore.
    Registered user. jmclaugh's Avatar
    Jun 2006
    Devon
    3,474
    A really lovely bracket clock and Regency ones are my favourites. Thomas Reid is a well known Scottish maker who was in partnership with William Auld from 1806 until he retired in 1823, died 1831. He was apprenticed in Edinburgh to James Cowan his cousin in 1762 and was then in London from 1770 and then Edinburgh again from 1781 when he succeeded Cowan.
    Good luck with sorting out the striking.
    Jonathan.
    Jul 2011
    77
    I was finally able to find the source of the problem with the strike. A piece within the train was bent outward just a hair too far, missing the catch. Now it's back in proper running order. The fret silk had obviously been replaced at one time, and was done very sloppily. I was fortunate to have come across a pristine piece of salvaged 19th century silk velvet. Also found a finer piece of wax cord for the repeat pull that closely matches the fret.
    can you upload the pictures to the server again please? they seem to have gone
    My William Webster has the same feature and the cord comes out the bottom with a little brass pull tab. The way mine is currently set, if you pull the string after about 10 till the hour you will get the next hour strike. I am not sure that is correct, but it is the only setting for the snail that lets the one o'clock strike occur properly without catching the tail on the snail as it rises from the 12 o'clock position. I don't think the pull string has anything to do with it, but is more likely that the tail is not dropping onto the one o'clock portion of the snail properly.
    The purpose of a discussion is to learn something, not to prove who is right. Dalai Lama
    Jul 2011
    77
    Quote Originally Posted by novicetimekeeper View Post
    Registered User prideofmatchingham's Avatar
    Kolkata, India
    1,233
    As the lever is to be pressed downwards for repeat to be activated, my hunch is that repeat hole should have been lower. That also is the case with my clock. Hole being so high up, almost in line with the mechanism, would exert sideways pressure on lever rather than downward.
    Unless ofcourse thats the way it was designed.
    Glad that silk has been replaced with the current red one. Makes it 'hot'!
    By the way, there seems to be a hole on the lower portion of the movement backplate. Possibly that is the place where brass pendulum movement lock was there along with the stabiliser knob. Possibly that explains another vacant hole on the movement support brass L where this knob fits.
    "Be nice to the people on your way up because you will meet them on your way down."
  1. Thomas Reid & William Auld Fusee Bracket Clock
    By JDCKent in forum Clocks General.
    Last Post: 02-14-2016, 10:11 AM
  2. D&W Morice single fusee bracket clock
    By suvro in forum Clocks General.
    Last Post: 01-24-2010, 06:46 AM
  3. Replies: 19
    Last Post: 04-14-2009, 04:01 PM
  4. Question for fusee bracket clock owners.....
    By SrWilson in forum Clocks General.
    Last Post: 05-23-2004, 01:40 PM
  5. ENGLISH FUSEE BRACKET CLOCK
    By clockbob in forum Clocks General.
    Last Post: 11-12-2002, 01:07 PM
