Results 1 to 2 of 2
    Default Replacing 10 inch painted with paper dial
    Existing black and white 10 inch painted dial completely flaked, no possibility of repairing. However I have taken a good photograph of a similar dial which could be transferred to paper and glued over the original. It is on an electric master clock.
    What would be the best paper (or material) to use, how would the photograph be transferred to the paper and what glue to use to attach it. Where would be a good place to get this done?
    If somebody has experience with this, I'd appreciate any advice,
    Regards
    Registered user. MartinM's Avatar
    El Dorado, CA
    2,226
    Default Re: Replacing 10 inch painted with paper dial (By: gmitche4)
    Convert your picture to a vector graphic and laser print it onto a heavy piece of acid-free paper (Check with framing shops) and secure it with contact cement.
    Living life at eight beats per minute.
  1. Ansonia black iron with paper dial
    By philliplederer in forum Clocks General.
    Last Post: 04-29-2010, 12:58 PM
  2. Mechanical Wristwatch Need Help with Paper Watch Dials
    By Waterbury Watch Guy in forum Watch Repair
    Last Post: 02-27-2007, 03:51 PM
  3. Paper dial replacement
    By Seth Thomas Fan in forum Clock Case Restoration and Repair.
    Last Post: 06-12-2006, 09:53 AM
  4. WHO SUPPLIES THE BEST PAPER DIAL REPLACEMENTS?
    By RAK in forum Clock Case Restoration and Repair.
    Last Post: 07-22-2005, 01:51 AM
  5. Paper dial replacement
    By crsides in forum Clock Repair
    Last Post: 10-16-2003, 12:47 PM
