Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Registered User John P's Avatar
    Sep 2010
    545
    Default Re: Delrin-AF bushings in wooden movement 7 & 10 year update (By: R. Croswell)
    Bob, I contacted you some 9=10 years ago regarding the use of delrin bushings in a Terry clock the was and is in a Historical home in the Kings Mountain Revolutionary park.
    We made bushings for almost every wheel, front and back. No oil was used in these bushings.
    The clock is still running to this day with no service whatsoever.
    Since then, I have used this material to repair several WW movements without a hitch.
    John
    God started the clock in Gen. 1:13
  2. #17
    Default Re: Delrin-AF bushings in wooden movement 7 & 10 year update (By: John P)
    That's great to know. It is important to know when others have success (or failure) whit new materials and different methods.
  1. Horn bushings in a wooden movement
    By Albert Crabtree in forum Wood Movement Clocks
    Last Post: 03-01-2014, 10:00 PM
  2. Bushing a Wooden Movement
    Last Post: 01-30-2014, 11:22 AM
  3. Bushings in a wood movement
    By Ronald Clark in forum Wood Movement Clocks
    Last Post: 09-30-2012, 01:58 PM
  4. Bushings in thin plate movements
    By harold bain in forum Clock Repair
    Last Post: 04-17-2012, 02:26 PM
  5. Replacing brass bushes in wooden frame
    By sedge in forum Clock Repair
    Last Post: 11-24-2008, 08:57 AM
