Goal: $300, Received: $125.00 (42%) Contribute Now
    Registered User Jerry Treiman's Avatar
    Los Angeles, CA
    4,920
    Default spacebar not working (intermittent problem)
    Periodically I am having trouble with the spacebar on my keyboard not being recognized in this text box, but it seems specific to this board. It functions fine in other applications and I can cut and paste my posts when this happens. (It is working now). Has anyone else had this problem?
    I have an iMac, running OS X El Capitan (v.10.11.6); Google Chrome browser (v.54.0.2840.98)
    Jerry Treiman, NAWCC member since 1971
    Charter member of Pocket Horology Chapter 174
    18,928
    Default Re: spacebar not working (intermittent problem) (By: Jerry Treiman)
    I do not recall seeing this. If keys are not active, it is often because some Javascript function is capturing that particular keystroke. Since the editor is written in Javascript that might be a bug in the editor.
    If I understand your report, all the other keys are working correctly when this happens.
    Los Angeles, CA
    4,920
    Default Re: spacebar not working (intermittent problem) (By: Tom McIntyre)
    I haven't tried all of the other keys, but the text keys seem to work. I can type a message or delete/backspace but cannot insert spaces.
    (spacebar is working right now).
    39,371
    I had the same problem a few days ago, but it went away.
    Default Re: spacebar not working (intermittent problem) (By: harold bain)
    I get the same problem, thought it were my computer but it is only on this site. When I get it I press return then back space and it all works again.
    Los Angeles, CA
    4,920
    Default Re: spacebar not working (intermittent problem) (By: novicetimekeeper)
    Quote Originally Posted by novicetimekeeper View Post
    Yes,thatworksformetoo.
    Yes, that works for me too.
  1. Problem with link not working
    By KurtinSA in forum MB User Help & Comments; Policy Questions
    Last Post: 09-22-2015, 09:52 PM
  2. Atmos Calibre 526 not working
    By Pep in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 06-14-2006, 10:24 PM
  3. United electric clock not working
    By Weight Driven in forum Electric Horology
    Last Post: 05-25-2006, 04:38 AM
  4. Hermle triple chime reset not working
    By Chris in forum Clock Repair
    Last Post: 11-05-2005, 12:18 PM
  5. Minte/Hour Hands not working issue
    By HenryB in forum Watch Repair
    Last Post: 05-11-2004, 05:35 PM
