    19,906
    Default Old clock shelf.
    I purchased this shelf and the seller stated he knew where it came from. A local family that had it in their home from the early 1900,s.
    It looks like walnut to me, and has a number stamped on the wood. The seller thought that since it has hinges and folds up maybe Eatons of Canada sold this through their store.
    Does this shelf from what you can see look to be old.Click image for larger version.
    Registered User richiec's Avatar
    Feb 2007
    Brick, Ocean, NJ
    5,249
    Default Re: Old clock shelf. (By: Kevin W.)
    Kevin, Doesn't look that old, check the type of nails and screws used, the hinges on the shelf look to be not too old. Cute shelf anyway.
    Quote Originally Posted by Kevin W. View Post
    I've seen many folding shelves like this before. In a "Black Forest" style, usually thin dark walnut (can be somewhat flimsy, too so no heavy stuff), somewhat crude shallow carving, coiled wire hinges, # stamped on the back which I always assumed to be a model or catalog #.
    They're rather common. Produced in great numbers. I think they were made to fold as that facilitated packing large #'s of them in crates for shipping. I don't believe that there is any other significance attributable to that characteristic nor does it suggest an origin.
    I suspect they were sold through many retail outlets. I bet you could even order them through your Sears catalog?
    Here are a couple of pix of one I own both without and with it's usual occupant:
Name:	folding shelf 2.JPG
ID:	321996Click image for larger version.
Name:	folding shelf 1.JPG
    Your shelf looks rather light in color. Harshly refinished or bleached?
    I have also seen basically repro's marked "India" which are of a lighter wood and tend to be more ornate.
    The carving and hinges for the supports on yours look right.
    RM
    19,906
    Default Re: Old clock shelf. (By: rmarkowitz1_cee4a1)
    Long as i know i have a antique and where it came from i am good, thanks for the comments everyone. The seller stated to me several times who knew the past owners of the shelf.
  1. Old Gilbert shelf clock pendulum quest.
    By orso in forum Your Newest Clock Acquisition
    Last Post: 10-24-2014, 12:16 AM
  2. Asking for help with old Junghans shelf clock
    By espresso in forum Clocks General.
    Last Post: 10-28-2010, 07:59 PM
  3. Any Old Clocks Made In Kentucky?
    By ShawnHVoils in forum Clocks General.
    Last Post: 06-29-2005, 09:10 PM
  4. Fitting a new hand to an old clock
    By Don K. in forum Clock Repair
    Last Post: 06-07-2005, 12:04 PM
  5. "This old Clock"
    By time4now in forum Clocks General.
    Last Post: 11-24-2003, 12:43 AM
