Goal: $300, Received: $185.00 (62%) Contribute Now
Thread: LINCOLN CLOCKS
    Wasting Time
    Guest
    Default LINCOLN CLOCKS
    I HAVE SEEN A FEW REFERENCES TO A LINCOLD CLOCK COMPANY - PRODUXING ELECTRIC CLOCKS IN THE EARLY 1900s.
    IS THERE A PLACE I CAN RESEARCH THIS COMPANY'S HISTORY?
    39,396
    Default LINCOLN CLOCKS (By: Wasting Time)
    Hi Ivan. If you are an NAWCC member, you could use their research facilities. It is not a company that I am familiar with. How is your research on the James Remind-o-timers coming? Harold
    Found amongst my "junk" a circa 1930 bakelite so-called "cathedral" style "Lincoln" synchronous electric clock with "ELECTRIC CLOCK CORP. OF AMERICA, CHICAGO" at the bottom of the dial, plus a nearly identical "Royal" which appears to have been made by the same manufacturer. Both are rather cheaply made and NOT self-starting. Don't think these are too rare-- if you keep checking ebaY you are bound to find other examples pictured.
    I have seen many "Lincoln" electrics over the years and all have been of the kind Jeff described, sort of generic cathedral-shaped non-self starting bakelite clocks with round dials, of the kind that were made in the early 30s. They seem reliable, as many do still run after 75 years, but not at all rare. Some other makers made the same or nearly the same style.
    Wasting Time
    Guest
    Thanks
    Atlanta GA
    17
    Default Re: LINCOLN CLOCKS
    Hi, I have a camel back wooden mantel variety that I am restoring. Should be a beauty, no chimes, I will post a pick of the face when I can.
    I found this: https://www.madeinchicagomuseum.com/...America-c-1932
    Prices range from .87¢ to $15, I think mine is the $9 model.
    Are you winding me up?
  1. Abraham Lincoln's Law Office Clock
    By Ralph in forum Horological Misc
    Last Post: 12-01-2011, 05:47 PM
  2. Help - Abraham Lincoln Clock - Japy Freres works
    By Dick C in forum Clocks General.
    Last Post: 09-09-2010, 06:46 AM
  3. Lincoln Electric Brass Lamp with Clock in the base
    By lwsjks in forum Electric Horology
    Last Post: 06-28-2010, 04:56 AM
  4. Replies: 10
    Last Post: 09-03-2007, 04:42 PM
  5. United Clock Co Model 975
    By Graham Mitchell in forum Electric Horology
    Last Post: 09-05-2005, 03:59 AM
Members who have read this thread: 22
