Goal: $300, Received: $185.00 (62%) Contribute Now
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Default Re: Black Forest Shield Sharpie Numerals (By: gleber)
    It is a huge improvement in draughtsmanship, but I agree could be a bit darker.
    Nick, lots to learn, late starter.
  2. #17
    Registered user. gleber's Avatar
    Jun 2015
    Downingtown, Pennsylvania USA
    523
    Blog Entries
    Default Re: Black Forest Shield Sharpie Numerals (By: novicetimekeeper)
    Quote Originally Posted by novicetimekeeper View Post
    Thanks Novice. Now I'm another step closer to actually doing that.
    Tom
  3. #18
    I would have used an ink or paint that is easily reversible, that would come off with a solvent that won't affect the rest of the dial. Ball point ink may be difficult to remove; it also may bleed over time into the surrounding paint.
    Jeremy
  4. #19
    Jun 2015
    523
    Blog Entries
    Default Re: Black Forest Shield Sharpie Numerals (By: Jeremy Woodoff)
    Quote Originally Posted by Jeremy Woodoff View Post
    Thanks for the comment Jeremy. I knew I didn't want opaque black since I probably won't attempt the artwork and can't afford a professional and don't think the clock is worth it. The previous sharpie version didn't look right even if it was done neater. It was either redo completely or work with what I got and try to preserve the look. I chose the latter. I was able to clean up my mistakes very well with a simple pencil eraser, but I think the ink is beginning to set. I can still erase some of it, but not as cleanly. The shade is just about right from across the room and it looks equally worn with the rest of the dial. I didn't think about the possibility of bleeding, but the painted surface does not seem very porous, so I hope I don't end up saying, I should have listened to Jeremy." And, hopefully I won't ever have to remove it.
    I do appreciate hearing your opinion.
    Tom
  1. Black Forest Shield Clock
    By gleber in forum Your Newest Clock Acquisition
    Last Post: 01-21-2017, 08:01 AM
  2. Replies: 7
    Last Post: 06-20-2016, 08:12 PM
  3. Black Forest Shield Clock
    By gozoish in forum Clocks General.
    Last Post: 03-18-2016, 06:30 AM
  4. Replies: 7
    Last Post: 07-13-2012, 07:20 PM
  5. A Rare Black Forest Shield Automaton of a Butcher "Metzgeruhr"
    By BLACK FOREST CLOCKS in forum Your Newest Clock Acquisition
    Last Post: 03-14-2011, 05:56 PM
