NOTICE Notice: This is an old thread. The last post was 370 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Registered user. gleber's Avatar
    Jun 2015
    Downingtown, Pennsylvania USA
    523
    Blog Entries
    Default Dial Discoloration
    When I first saw the discoloration on this dial, I thought it was wear from the clock's hands rubbing on the dial, but after looking more closely, I think I have come to realize a lot of this type of wear is probably from the owner's hands (or fingers) when they set the time. Is that a more common cause of dial wear that looks like this? Also, is there a recommended way to clean this? I'm happy to keep is as is, rather than make it worse, but I'm curious about how much can be done without a complete redo...
    The whole clock can be seen here: http://mb.nawcc.org/showthread.php?1...-DUFA-Specimen
    Tom
    Registered user. MartinM's Avatar
    Jun 2011
    El Dorado, CA
    2,203
    Default Re: Dial Discoloration (By: gleber)
    I'm sure fingers do their share of damage. As well as hands pressed against a dial when setting the time, but, this looks more like maybe someone was cleaning the dial with a rag while trying to work around the hands and the cleaner left residue, unevenly, that developed the variegated patina.
    Living life at eight beats per minute.
    Jun 2015
    523
    Blog Entries
    Hmm, yeah, that makes the most sense given the pattern.
    Thanks for the input.
    Tom
  1. Dial Restoration (before and after pics)
    By Sooth in forum Clock Case Restoration and Repair.
    Last Post: 10-18-2016, 02:39 PM
  2. Semca double dial clock
    By Jim Myers in forum Clock Repair
    Last Post: 06-25-2006, 09:39 PM
  3. Discolored mercury in crystal regulator pendulum
    By Susan Rogan in forum Clock Repair
    Last Post: 06-06-2005, 04:46 AM
  4. Illinois Pocket Watch Dials
    By Ken Hags in forum American Pocket Watches
    Last Post: 08-29-2002, 08:07 AM
  5. When/or would you repair a dial?
    By Cary in forum American Pocket Watches
    Last Post: 03-27-2002, 06:33 AM
