Goal: $300, Received: $165.00 (55%) Contribute Now
Page 4 of 4 FirstFirst 1234
Results 46 to 47 of 47
  1. #46
    Default Re: first fusee movement: several questions (By: Ralph)
    gang -
    the repainted dial is on its way back to me... very excited.
    in the meantime, i couldn't figure out why the movement would keep stopping after i had cleaned and re-assembled it.
    and then i realized that i hadn't lubricated the chain enough... so i re-lubed and worked every link manually just to make sure they all felt nice and loose (enough).
    and then it stopped again.
    and then i realized that i simply hadn't put enough pre-wind on the barrel spring, and it just didn't have enough power. i had been trying 1.5-2 winds, but it didn't perk up until i had 3.5-4 winds on it... at which point it suddenly seemed to wake up and be fine. in fact, it gave me a somewhat disgusted look, as if to say: why didn't you do that before, so i didn't have to strain?!?! 't's been running ever since.
    btw, i did check the spring, which looked newer/cleaner, and lubed.
    i'll post some pics when it's all back together.
    thx to all for the tips.
    smike
    i collect antique clocks because i get all that extra time...
  2. #47
    Default Re: first fusee movement: several questions (By: bruce linde)
    never got around to posting a pic of the re-painted dial and done clock....
  1. Disassembly of Fusee Movement - First time
    By Probox in forum Clock Repair
    Last Post: 01-17-2016, 07:23 PM
  2. Compensation Curb; when was it first used? Did Fusee movements have it?
    By Omexa in forum European & Other Pocket Watches
    Last Post: 12-04-2013, 12:18 PM
  3. First watch ... several questions
    By GRHunter in forum American Pocket Watches
    Last Post: 09-06-2010, 01:33 PM
  4. First Fusee
    By shutterbug in forum Clock Repair
    Last Post: 08-11-2006, 03:30 AM
  5. Sessions movement repair question
    By Bob Kellett in forum Clock Repair
    Last Post: 05-19-2005, 06:52 AM
