Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
  1. #16
    Default Re: first fusee movement: several questions (By: novicetimekeeper)
    Quote Originally Posted by novicetimekeeper View Post
    That seems likely, could be a London Borough. https://en.wikipedia.org/wiki/London_County_Council
    However Kent County Council was also formed in 1889
    Either way the clock could be older
    here are photos... the dial was paper on a steel plate and is out being re-painted. the movement runs great, even though it hasn't been cleaned or set up yet.
ID:	304440Click image for larger version.
ID:	304448Click image for larger version.
ID:	304447Click image for larger version.
ID:	304446Click image for larger version.
ID:	304445Click image for larger version.
ID:	304443Click image for larger version.
ID:	304442Click image for larger version.
ID:	304441Click image for larger version.
    i collect antique clocks because i get all that extra time...
  2. #17
    Default Re: first fusee movement: several questions (By: bruce linde)
    That looks like it was originally made for LCC, which would be right for the construction style so post 1889
    Nick, lots to learn, late starter.
  3. #18
    post 1889, but pre-what?
    got any idea of 'between 1889 and _______'?
  4. #19
    Registered User gmorse's Avatar
    Jan 2011
    6,858
    Blog Entries
    Hi smike,
    A lot of these were made by Thwaites & Reed, who still exist, so they might be able to help you with this, although I don't know how comprehensive their records are.
    "Ut tensio, sic vis" - Robert Hooke
  5. #20
    Quote Originally Posted by smike View Post
    Well LCC was replaced in 1965 but I would have thought with a chain fusee your are no further than the first quarter of the 20th Century. I would have expected T&R to have their own stamp on the movement but they may at least be able to tell you when they stopped making chain fusee dial clocks.
    EDIT :
    Well I'm amazed, now I've done a bit of research. They were still making chain fusee dial clocks virtually right up to the demise of London County Council, certainly in the fifties.
    There is a specialist who will give you an appraisal for a fee, he specialises in railway clocks but he can probably help. He charges £12 for an appraisal, but if you email him he can advise if he can help with your clock.
  6. #21
    According to Richard Rose's list of Dial Clock movement serial numbers produced by Thwaits; they manufactured serial numbers 15317 through 16734 during the period 1889 through and including year 1910 for a quantity of over 1400 serial numbered movements during that twenty year period.
    On the basis of the subject movement serial number (17207) One might figure it would have been produced ten years after their circa 1910 production figure of (16734) or about 1920 but some consideration to the effects of WWI could have on the production of domestic clocks.
    H.J. (Les) Lesovsky, Alhambra California
  7. #22
    Default Re: first fusee movement: several questions (By: eskmill)
    Quote Originally Posted by eskmill View Post
    According to Richard Rose's list of Dial Clock movement serial numbers produced by Thwaits; they manufactured serial numbers 15317 through 16734 during the period 1889 through and including year 1910 for a quantity of over 1400 serial numbered movements during that twenty year period. On the basis of the subject movement serial number (17207) One might figure it would have been produced ten years after their circa 1910 production figure of (16734) or about 1920 but some consideration to the effects of WWI could have on the production of domestic clocks.
    guys -
    i appreciate the detective work! i reached out to thwaits, and they said they only had records (maybe) for movements that had their name and/or mark on them... but did appreciate my pointing out that the 'email us' link on their website displays properly to the user but is still coded to the default 'your@address.here'... that doesn't really qualify for the webmaster hall of shame, as i've seen it too many times! 8-)
    anyway, i've got hands on the movement, i'm going to regulate it, and i'm going with 'about 100 years old'.
    i will post photos when i get the re-painted dial back.
    thx again,
    smike
  8. #23
    Jan 2011
    6,858
    Blog Entries
    Hi Les,
    ...According to Richard Rose's list of Dial Clock movement serial numbers...
    Did you mean Ron Rose?
  9. #24
    Default Re: first fusee movement: several questions (By: gmorse)
    Hey Smike - it would be best to upload your photo's to our site. Eventually, the 3rd party site will dump the photo's, and the thread will be unusable to future searchers. Use the white camera icon in the reply window.
  10. #25
    Graham asks, "Did you mean Ron Rose?"
    Yes, my data to guess on the date of Smile's clock, I used Ronald Rose's massive data in his book "English Dial Clocks."
  11. #26
    Default Re: first fusee movement: several questions (By: shutterbug)
    Quote Originally Posted by shutterbug View Post
    huh? I always upload photos... including those. why do you think otherwise?
    smike
  12. #27
    smike
    Firstly, the images posted as inserted reside as a part of your post or reply and are not stored on the NAWCC's photo repository site whereas appended images become copyright jointly between you and NAWCC and therefore enjoy copyright protection.
    Secondly, although you own the original images you have inserted into your post or reply, you have little recourse if an image is miss-used or lost without your consent by just about anybody with internet access.
    And, as Shutterbug advises, if your images are stored on your own or a third party's facility and become lost or unaccessable, your image(s) effectively disappear.
    Correct me if I misunderstand the general guidelines and rules concerning photos and images used on this site.
  13. #28
    I've got that book by the side of me and didn't realise it had a list of thwaites serial numbers in it! I'm glad the date came out there though rather than later.
  14. #29
    ok, now I'm confused... the big banner says 'use the camera icon to upload photos... which is what I'm doing
    pls tell me what other procedure to use... as well as how one tells whether images are appended or uploaded, etc
    as a professional webmaster, I have absolutely no idea of what you're talking about… yet
    please de-confuse me
    thx
  15. #30
    i use the white camera option every time.
    so... what specifically makes you say/think i'm NOT uploading the photos to the nawcc site?
    if using the white camera icon doesn't upload them to the nawcc site...
    1. where are they getting uploaded to?
    2. why do the direct urls for the images start with http://mb.nawcc.org/attachment.php?a...______________ ?
    once i've uploaded them, i double-click on each one to select 'large'... which is why they appear full-size in posts... but as someone who builds such websites, i would be shocked to find that this site was somehow uploading images to and then accessing them from a non-nawcc server. it typically doesn't work that way.
    i'm thinking YOU'RE thinking i've got those big images stored elsewhere... is that the case?
    if not, please provide more specific 'what to look for' and 'how best to upload image' instructions... in painfully explicit detail, so i can not muck things up.
    thx,
    smike
  1. Disassembly of Fusee Movement - First time
    By Probox in forum Clock Repair
    Last Post: 01-17-2016, 07:23 PM
  2. Compensation Curb; when was it first used? Did Fusee movements have it?
    By Omexa in forum European & Other Pocket Watches
    Last Post: 12-04-2013, 12:18 PM
  3. First watch ... several questions
    By GRHunter in forum American Pocket Watches
    Last Post: 09-06-2010, 01:33 PM
  4. First Fusee
    By shutterbug in forum Clock Repair
    Last Post: 08-11-2006, 03:30 AM
  5. Sessions movement repair question
    By Bob Kellett in forum Clock Repair
    Last Post: 05-19-2005, 06:52 AM
