Goal: $300, Received: $360.00 (120%) Contribute Now
Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
    Registered User AGBlex's Avatar
    Oct 2012
    North East
    66
    Default Unknown E. Ohm San Francisco Pocket watch Maker KW info?
    Literally can't find any info on it. Help would be wonderful . Measures 48.8mm across
    Default Re: Unknown E. Ohm San Francisco Pocket watch Maker KW info? (By: AGBlex)
    A photo of the movement is somewhat necessary to ID your watch. Private-label watches can be from many different makers for the same label. And it's nearly certain that yours is a private-label watch. At least I have never heard of the name "Ohm" as a watchmaker, or jeweler for that matter. Good luck.
    Registered user.
    Jan 2009
    So. Calif.
    3,208
    On my 13-year-old computer with dial-up connection (which I mention only to perhaps elicit sympathy or at least understanding), using a Google search and various sources that it led me to, including a San Francisco business directory from c.1880, I managed to find out that (listed under watchmakers and jewelers) there was an Edward F. Ohm, doing business at 604 Merchant Street in San Francisco!!! I apologize for that long sentence; I just let it flow!
    I found no other more specific information on Ohm's business or any watches. A search on this message board brought up a bunch of threads that were mainly on on the Electric Horology forum, as I expected it would!
    I agree with MrRoundel; a photo of the movement would be essential to further discussion.
    I just had an irrelevant after-though that, if I were wise, I would keep to myself. Apparently I'm not [wise], so here goes nothing! Could it be possible that at some time long ago and in some distant land, Mr. Ohm's ancestors were perhaps named Watt or Volta or Ampere, but decided to join a "resistance" group of some sort, and therefore changed their name to Ohm? Okay, I apologize for that. Save your over-ripe tomatoes and make some pasta sauce instead. Yes, I probably do have too much time on my hands! <];>)
    Larry Treiman
    Hi Larry, I love your little diversion from reality with your story about "Ohm". Just to make you a little bit upset; not really, I just had NBN optic Fiber internet connected to my Quad Core Xeon Computer. Regards Ray
    Default Re: Unknown E. Ohm San Francisco Pocket watch Maker KW info? (By: Omexa)
    I used to own a micrometer marked "Ohm / S.F." on each part. I looked him up in the S.F. Library and found he was in business long enough that he was listed in an early S.F. phone book. Next time I see the present owner I will ask to get a picture.-Cort. p.s.- I just remembered I also used to own an early private label Lange pocket watch movement signed Frederic Ohm S.F.. The ser. No. was around 3xxx. so roughly 1860s.-C
  6. #6
    Oct 2012
    North East
    66
    Default Re: Unknown E. Ohm San Francisco Pocket watch Maker KW info? (By: 4thdimension)
    I apologize. I thought this photo added earlier... here it is again. dial side is plain with a few hairlines but nothing fancy
  7. #7
    A very nice movement that I have not seen before. Regards Ray
  8. #8
    Whoa! Beautiful. Maybe perhaps a German watch too? That guess based solely on the shape of the balance cock.-Cort
  9. #9
    awesome watch! scant info...
    A mention here: http://cdnc.ucr.edu/cgi-bin/cdnc?a=d...8661101.2.37.4
    a lawsuit here:https://books.google.com/books?id=y2...patent&f=false
    and several lawsuits.
    back to the watch any serial numbers?
    Jeffrey P. Hess, collector, historian, writer, CEO Ball WATCH USA
  10. #10
    Oct 2012
    North East
    66
    Default Re: Unknown E. Ohm San Francisco Pocket watch Maker KW info? (By: Jeff Hess)
    No serial numbers that I can see. but I have not removed the dial. lots on this guys problems!!!! I hope it all leads to the maker and what or where the movements went!
  11. #11
    in 1861 he was noted as an "importer for many years" of watches. https://books.google.com/books?id=r5...&q:^hm&f=false
  12. #12
    If we think this is a European watch, I can move the thread over to the European forum. Maybe some folks over there can ID it. I'll leave the thread here for now until someone says something definite about its origin.
  13. #13
    Oct 2012
    North East
    66
    Default Re: Unknown E. Ohm San Francisco Pocket watch Maker KW info? (By: Dave Coatsworth)
    Maybe moving it should work, I was hopeful here , but San Fran was a long way to travel back then especially for a little watch
  14. #14
    OK. Moving to the European forum, hopefully for an ID on the movement.
  15. #15
    Oct 2012
    North East
    66
    Thank very much
  1. unknown swiss pocket watch maker owl symbol
    By AGBlex in forum European & Other Pocket Watches
    Last Post: 02-03-2013, 08:15 AM
  2. Unknown Pocket watch maker
    By Jhere66061 in forum European & Other Pocket Watches
    Last Post: 07-06-2008, 08:34 PM
  3. Quality swiss pocket watch maker initials ring a bell?
    By Luca in forum American Pocket Watches
    Last Post: 02-03-2007, 12:18 PM
  4. Alarm Pocket Watch Maker ?
    By harold in forum American Pocket Watches
    Last Post: 06-28-2006, 03:48 AM
  5. Universal Geneve Pocket Watch Makers Marks ????
    By java1214 in forum American Pocket Watches
    Last Post: 12-04-2004, 11:35 PM
