Notice: This is an old thread. The last post was 2551 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
06-25-2006, 11:37 AM #1og_boyGuest
sligh westminster chime lockout lever?
bought a newer sligh mantel clock with westminster chimes and fixed it I guess-it would go 3 quarter hours then skip one . it had a -(is a hermle movement)- unexplained to me extra locking lever on the sort of 4 sided westmenster cam that I wired up out of the way now it seems towork good anybody know the purpose of it?the cam is on the upper riaht side looking at the front of the movement
06-25-2006, 11:37 AM #2og_boyGuest
06-25-2006, 11:57 AM #3
Is the lever inside the plates? If so, it is probably the chime correction lever.. brings the chime and hands back in agreement when they get off. Clock will work without it, but will not self-correct.
Misallignment of the two "cams" on the front of the plate on the chime train is the problem. Or possibly too little warning in the chime train
Not sure I can describe how to set it up properly without one in front of me. Perhaps someone else can do it from memory.
This is a good learning opportunity as most chiming clocks use some variation of this set-up to do chime correction.
DavidDavid Robertson - Kingsland, TX
06-25-2006, 12:30 PM #4Mark A. ButterworthGuest
It is indeed the chime correction lever. Our experience generally is that does not lift high enough on the hour.
There is a simple fix. The chime unlocking lever is a v-shaped device actived by the star wheel on the minute arbor and raises the locking lever for the chimes. Open the V somewhat and it will raise the locking lever higher.
06-25-2006, 11:46 PM #5Registered User
- Join Date
- Nov 2005
- Posts
- 242
Mark has described the problem perfectly. The cause of this is the customer spins the minute hand forward without waiting for the quarterly chimes. Jamming occurs and the v shaped lever squeezes a bit and now cannot lift high enough for the self correcting device.
Jeff Major
Vancouver, Wa.
French mechanical movement - ave maria & westminster chimes. Chime selection lever??
By NEWOSA65 in forum Clock RepairReplies: 1Last Post: 01-21-2012, 06:48 PM -
Garrard Westminster clock broken chiming/silent lever
By maxperondi in forum Clock RepairReplies: 10Last Post: 05-12-2009, 03:07 PM -
Junghans Westminster Chime Clock Washington #17201
By Giftgal in forum Clock RepairReplies: 18Last Post: 09-04-2006, 06:40 PM -
verichron westminster chime clock
By bufordcat in forum Clocks General.Replies: 3Last Post: 01-29-2006, 10:30 PM -
8 Day Mauthe Westminster Chimes
By Mike Phelan in forum Clocks General.Replies: 0Last Post: 05-09-2005, 05:08 PM
About the Message Board
This will be an ongoing blog to chronicle the development and use of the NAWCC Message Board. Please reply with your thoughts as you feel appropriate. June 2013 marks the deployment of the last edition of vBulletin V4. We will continue using this version of the software until vBulletin V5 has been widely deployed and had a thorough shakedown. That may take as much as 3 years. In order to freshen the look of the message board, several changes have been made in this deployment. The most...
05-31-2013, 04:23 PM in Tom McIntyre
