Goal: $300, Received: $20.00 (7%) Contribute Now
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
  1. #31
    Registered user.
    Dec 2012
    Santa Rosa,CA
    356
    Default Re: Parts needed for a Kern U Sohne (By: Tunderer)
  2. #32
    Registered User Burkhard Rasch's Avatar
    Jun 2007
    Twistringen
    4,050
    Default Re: Parts needed for a Kern U Sohne (By: sjaffe)
    maybe this
    Jahresuhren / Homepage
    could help.
    Burkhard
    Gigni de nihilo nihil,et nihil in nihilum posse reverti
    (Persius)
  3. #33
    Default Crown Pediment for a GB (By: John Hubby)
    I am looking for a crown / pediment for this GB.
    Thanks.
  4. #34
    Registered User KurtinSA's Avatar
    Nov 2014
    San Antonio, TX
    1,583
    Default Re: Crown Pediment for a GB (By: Laird)
    What would it look like? The pediments on my GBs vary somewhat.
    Kurt
  5. #35
    Default Re: Crown Pediment for a GB (By: KurtinSA)
    Like this one - borrowed from a pic kindly posted by Pollythecat.
  6. #36
    Nov 2014
    San Antonio, TX
    1,583
    I'm not that familiar with all the variations, but I have something that has a similar looking bridge with 52mm between hole centers but the finials aren't that "fancy". Not to mention that two of the finials are broken off.
    Kurt
  7. #37
    Thank you.
    From your description, it sounds like the condition is not as good as I would like so I think I will hold off and continue looking.
    I appreciate you taking the trouble to respond.
  8. #38
    Nov 2014
    San Antonio, TX
    1,583
    Looking for a C-suspension piece plus fasteners for a JUF crystal regulator. It's the backwards C-looking time in the picture...sorry a little blurry. I might have to get someone to make one, but thought I'd check to see if there's one in someone's spare parts bin.
    Thanks...Kurt
  9. #39
    Registered user. Ingulphus's Avatar
    May 2006
    Oakland, CA
    706
    You can buy a replacement on eBay; search for "special suspension block". The seller (not me, I should add)
    sells a variety of replica parts and they are of good quality.
    Si non caste, tamen caute...
  10. #40
    Nov 2014
    San Antonio, TX
    1,583
    Default Re: Crown Pediment for a GB (By: Ingulphus)
    Thanks...I was directed to a seller in Australia. Seems like they're good reproduction parts. Now to dust off my PayPal account!!
    Kurt
  11. #41
    Nov 2014
    San Antonio, TX
    1,583
    Default Konrad Mauch Foot (By: KurtinSA)
    Have a Konrad Mauch miniature with "Diana" on the dial. The clock came with 4 feet which are independently adjustable. However, one of the bogus feet was glued on! I removed it and cleaned up the threads...now I'm looking for a replacement foot. The foot is 10.9mm tall and 13.1mm at it's widest point.# The threads are M4x0.7. I've checked with Chris Nimon and he came up empty. Below is the clock along with the correct foot. Any ideas? I took 3 nuts from the hardware store and glued them in a stack...it works but looks awful.
    Thanks...Kurt
ID:	349124Click image for larger version.
  12. #42
    Registered user. MartinM's Avatar
    Jun 2011
    El Dorado, CA
    2,300
    Default Re: Konrad Mauch Foot (By: KurtinSA)
    I'd drill it out and insert a piece of brass stock that would be redrilled and tapped.
    Could you drill out the top of the foot enough to JB Weld one of those nuts in it?
    If you do a clean job and touch it up with some brass paint (Provided you couldn't find a brass nut in that size), it should be pretty unnoticeable.
    Living life at eight beats per minute.
  13. #43
    Nov 2014
    San Antonio, TX
    1,583
    Default Re: Konrad Mauch Foot (By: MartinM)
    Martin -
    You can see the replacement foot that came with the clock. I was really looking for a "real" replacement. I attended a lecture at the National about 3-D printing. This would be a possibility for that kind of "repair". According to the lecture, he prints with something like 70% brass power and 30% plastic filler. Then the item is cleaned up...seems to work great for finials which might be painted. I do know someone locally who has a 3-D printer...hmmm...
    Kurt
  14. #44
    Nov 2014
    San Antonio, TX
    1,583
    I decided to get a 3-D print of the foot. Had a friend create the electronic file and then uploaded it to a company out of New York. For the first printing, I got free shipping, so the item cost me less than $5. I chose yellow plastic just to see how it would work. I've drilled and tapped the printed foot. The picture I've taken doesn't show so well. The knurling on the edge is not quite the same, but decent. I haven't decided if I'm just going to paint my plastic part and call it good, or reprint the next time with a brass material...probably would print all four so they would be matching. I'll play a little bit with painting to see how it would look.
    Kurt
ID:	352491Click image for larger version.
  15. #45
    Default Re: 400-Day & Torsion Clock Parts Wanted (By: etmb61)
    Komo in need of suspension spring. What size?
  1. 400-Day and Torsion Clock page is'nt fully loading?
    By Jeff C in forum MB User Help & Comments; Policy Questions
    Last Post: 02-25-2007, 11:54 AM
  2. Urgos clock part wanted
    By shutterbug in forum Clock Repair
    Last Post: 09-01-2006, 09:16 AM
  3. Elgin 400 day open gear clock
    By harold bain in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 12-10-2005, 08:39 AM
  4. trying to identify old 400 day disc pendulem clock
    By ryanleigh in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 05-23-2005, 02:13 AM
  5. Getting a 400 day disc pendulum clock to keep good time
    By doug sinclair in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 01-13-2004, 02:31 PM
