Goal: $300, Received: $250.00 (84%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 749 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 1 of 1
    Registered User Noel Poirier's Avatar
    Jul 2007
    Columbia, Pennsylvania
    97
    Default 1880s Tiffany & Company (Lefebvre) Shelf Clock
    Shelf Clock, c. 1885, Tiffany & Company. French made black slate case clock w/ brass mounts. Two Greek carytids and slate on front. Blue floral decorative plate on front with brass detail. Two side flowers in brass. Dial is slate with Roman numerals and gold leaf pattern design in center. Height:13". Base is 15" at feet. Depth: 6 ¾". Dial marked “Tiffany & Company, New York”, Movement marked “Lefebvre & Fils, Paris”.
ID:	269448   Click image for larger version.
ID:	269447   Click image for larger version.
ID:	269446   Click image for larger version.
ID:	269445   Click image for larger version.
ID:	269442   Click image for larger version.
ID:	269441   Click image for larger version.
    Noel B. Poirier
    National Watch & Clock Museum
  1. September's Object - Year Clock Company Shelf Clock
    By Noel Poirier in forum National Watch and Clock Museum
    Last Post: 09-05-2012, 05:52 AM
  2. Ansonia Australia Shelf Clock Parts
    By buzmarek in forum Clock Repair
    Last Post: 10-31-2006, 01:21 AM
  3. Ingraham Kitchen Shelf Clock
    By ladutka in forum Clock Repair
    Last Post: 02-19-2004, 06:54 AM
  4. Ansonia "Triumph" shelf clock Circa late 1880's
    By Robertsclocks in forum Clock Repair
    Last Post: 11-28-2003, 01:27 AM
  5. Massachusetts Shelf Clock Identification
    By Andy Dervan in forum Clocks General.
    Last Post: 11-24-2003, 10:07 AM
