    Registered user. KLS's Avatar
    Apr 2014
    Netherlands
    69
    Default Re: Fhs 261-080
    These pictures show the step-by-step disassembly of a Hermle 261-080 two-train weight driven movement. They were posted by Klaas in This Thread.
    They are copied here, with his permission, as a visual tutorial, both of how to disassemble a movement and how to take a thorough series of pictures for later reference.
    bangster
    moderator
    First in a series of Four groups
ID:	255989Click image for larger version.
ID:	255988Click image for larger version.
ID:	255990Click image for larger version.
ID:	255987Click image for larger version.
ID:	255986Click image for larger version.
ID:	255985Click image for larger version.
ID:	255984Click image for larger version.
ID:	255983Click image for larger version.
ID:	255982Click image for larger version.
    Klaas
    "Le Bricoleur"
    Apr 2014
    Netherlands
    69
    Default Re: Fhs 261-080 (By: KLS)
    Second in a series of Four groups
ID:	255992Click image for larger version.
ID:	255993Click image for larger version.
ID:	255994Click image for larger version.
ID:	255995Click image for larger version.
ID:	255996Click image for larger version.
ID:	255997Click image for larger version.
ID:	255998Click image for larger version.
ID:	255999Click image for larger version.
ID:	256000Click image for larger version.
    Klaas
    "Le Bricoleur"
    Apr 2014
    Netherlands
    69
    Third in a series of Four groups
ID:	256002Click image for larger version.
ID:	256003Click image for larger version.
ID:	256004Click image for larger version.
ID:	256005Click image for larger version.
ID:	256006Click image for larger version.
ID:	256007Click image for larger version.
ID:	256008Click image for larger version.
ID:	256009Click image for larger version.
ID:	256010Click image for larger version.
    Klaas
    "Le Bricoleur"
    Apr 2014
    Netherlands
    69
    Fourth in a series of Four groups
ID:	256012Click image for larger version.
ID:	256013Click image for larger version.
ID:	256014Click image for larger version.
ID:	256015Click image for larger version.
ID:	256016Click image for larger version.
ID:	256017Click image for larger version.
ID:	256018Click image for larger version.
    Now clean it...Make it ready for inspection...
    Klaas
    "Le Bricoleur"
  1. Hermle Auto Beat 261-080/21
    By Candix in forum Clock Repair
    Last Post: 12-29-2013, 11:42 PM
  2. Sessions Two-Train Westminster Disassembly
    By Jeff56 in forum Clock Repair
    Last Post: 03-17-2007, 08:10 PM
  3. Hermle 261-030 or 080 movement
    By DrewV in forum Clock Repair
    Last Post: 03-03-2005, 12:02 AM
