NOTICE Notice: This is an old thread. The last post was 5441 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 2 of 2
    Arrow BOOKREVIEW: 1759 text: Ferdinand Berthoud, How to regulate...
    How to Manage and Regulate Clocks and Watches. For the use of those who have no knowledge of Horology
    By M. Ferdinand Berthoud
    Paperback, 21x14cm, 81 pages, Equation Tabels, 4 Plates, 1999, first English Translation (by Lawrence Alan Seymour) of the French 1759 classic "L'art de conduire et de régler les Pendules et les Montres. A l'usage de ceux qui n'ont aucune connaissance d"Horlogerie", with an introduction by Paul Middents.
    The first timekeepers were used as scientific instruments for highly educated scholars and as playthings for kings and noblemen. But by the mid eighteenth century in Europe watches and clocks had become common enough that that a sizable portion of merchant classes like urbon shopkeepers was likely to own or aspire to own a timepiece, but these machines were still novel enough that most owners did not understand them or know how to use them, nor set them. In 1759 the distiguished Paris based Horologist Ferdinand Berthoud, "with the approval and assent of the King", saw an opportunity for what can faily be described as one of the first mass market books on timekeeping.
    While today Berthoud is better known for perfecting the equation clock, and his later, scholarly works on horological theory and horological science, few of his texts were so widely published as this little brochure. In the next 60 years it went through 6 editions in French (including one each in Holland and Belgium), was translated into Spanish and Italian three times each, and was published in German twice, as well as in Dutch. But untill L.A.Seymour, a NAWCC member in Washington State, translated and published the text in English in 1999 it was quite inaccessible to English speaking readers.
    While from todays perspective some of the text seems quaint, we must remember that the mid 18th century was basically a nonmechanical era, and even simple mechanical concepts like friction, lubrication or "storing power in a spring or by raising a weight" were virtually unknown to the intended audience. Even before providing instructions on how to set a timekeeper the author had to introduce such concepts as solar time vs. mean time which Berthoud does simply and elegantly at the beginning of the text. Other chapters deal with evaluating and selecting a reputable watchmaker, and with proper maintenance.
    The translator/publisher deserves the gratitude of horological enthusiasts for making this classic work finally available in English 340 years after its first publication.
    Reviewed by Fortunat F. Mueller-Maerki (New Jersey)
    FortunatMueller-Maerki, Sussex NJ
    NAWCC Life # 174
    Chair, NWCM Library and Research Center Committee
    You can reach me at horology@horology.com
    Fortunat Mueller-Maerki, -Chair NAWCC Library Com./ Editor & Publisher of BHM
    Mem.NAWCC Mus.Coll.Com. / VP, USA Sect. Antiq.Horolog.Soc.
    Default Review: 1759 text: Ferdinand Berthoud, How to regulate... (By: Fortunat Mueller-Maerki)
    NAWCC Life # 174
  1. How to regulate a verge
    By protec in forum European & Other Pocket Watches
    Last Post: 06-18-2008, 12:28 PM
  2. How to regulate a verge watch?
    By Anders in forum Watch Repair
    Last Post: 02-02-2008, 10:25 AM
  3. how to regulate a slow atmos
    By DML Clocks in forum Clock Repair
    Last Post: 04-26-2006, 03:16 PM
  4. How to regulate a floating balance
    By Chris in forum Clock Repair
    Last Post: 12-12-2005, 09:20 AM
  5. how to regulate time on Hermle 340-020
    By Donald P Bellamy in forum Clock Repair
    Last Post: 08-28-2005, 03:37 AM
