Goal: $300, Received: $215.00 (72%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3983 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Default Won't stop cuckooing
    I just acquired a used old cuckoo clock. It cuckoos continuously on the hour or half hour.I can only stop it by removing the weight or moving the minute hand about 20 min forward. The cuckoo won't retract either.
    Default Won't stop cuckooing (By: clock6331)
    Nov 2001
    South Easton, MA
    2,430
    Blog Entries
    If you can remove the movement, check the front of the clock to see if the brass stop is loose; it looks like a brass snail located to the upper right of the canon pinion. If that is misaligned or missing, the clock will not stop going off.
    In the same vein, you could also check the stop arm that engages with that brass piece to see if it's stuck in the upward position. If it is, that could cause a run-on as well. Let us know how it turns out.
    Thanks Chris. Armed with a printout of your instructions, I started to take the movement out. I took off the lift wires and something clicked and the cuckoo retracted. It works OK now. I can't explain it. I guess I scared it or something !!
    Thanks again.
    Clock6331
    Apr 2002
    20,120
    Blog Entries
    Thanks too Chris, i have a cuckoo that does the same thing.I will get to it one day.It is a older cuckoo clock.
  1. Cuckoo won't stop cuckoo-ing!!
    By Nifbu in forum Clock Repair
    Last Post: 04-20-2015, 10:19 AM
  2. won't stop striking
    By dutch in forum Clock Repair
    Last Post: 03-06-2006, 03:29 AM
  3. Seth Thomas Won't Stop Striking - Again!
    By Randy Johnson in forum Clock Repair
    Last Post: 12-11-2005, 08:37 AM
  4. Schatz Royal Mariner - Bell won't stop
    By ScottG in forum Clock Repair
    Last Post: 07-04-2005, 12:54 PM
  5. Darned thing won't stop striking
    By deena in forum Clock Repair
    Last Post: 02-14-2003, 11:50 PM
