NOTICE Notice: This is an old thread. The last post was 2124 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 10 of 10
    Default R5Y Motor for Seth Thomas Chime
    I have a Seth Thomas Model E721-001 mantel chime clock in for repair that needs a new motor. I do not know whether the internal motor gearing is OK, but the coil looks shot, like it has overheated. This is not an A300-100 capsule but appears to be a somewhat later design. The 10-tooth gear coming out of the sealed gear casing turns approximately 3.5 turns per minute. The coil (which snaps onto the casing with interlocking metal fingers) bears a tag "G.T. Motor" and a marking "M5A-60C-115V." The casing has a printed stamp "R5Y." I have been unable to find anything like this in any of my supply catalogs. Is there someone who can direct me to an appropriate replacement motor?
    Thanks and God Bless,
    Jeff Zimmer
    Default R5Y Motor for Seth Thomas Chime (RE: Jeff56)
    Jeff Zimmer
    Jeff Zimmer
    Jeff Zimmer
    Nov 2002
    38,599
    Jeff, try American Time and Signal, They should be able to help you. http://www.atsclock.com Good luck, Harold
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  6. #6
    Nov 2002
    38,599
  7. #7
    Registered User Tom Kloss's Avatar
    Dec 2003
    N.E. Pennsylvania
    1,855
    Can you post a picture of the motor?
    Sometimes you just don’t know if your being rewarded or punished
  8. #8
    Dec 2003
    N.E. Pennsylvania
    1,855
  9. #9
    Default Re: R5Y Motor for Seth Thomas Chime (RE: Tom Kloss)
    Hi there Jeff:
    Have you ever found a replacement motor for that specific clock? I too, have a customer that brought that exact same clock into the shop and it too, is in dire need of the exact same motor.
    If at all possible, please contact me at the shop to let me know.
    Thanks so much in advance.
    216-671-9504
    Die Klockwerken Antique CLock Repair & Restoration
    Cleveland, Ohio
    216-671-9504
  10. #10
    Default Re: R5Y Motor for Seth Thomas Chime (RE: klockwerken)
  1. need sangamo motor for Seth Thomas
    By John Echternach in forum Electric Horology
    Last Post: 11-11-2008, 06:28 PM
  2. Electric motor for Seth Thomas E720-001
    By Bruce J in forum Clock Repair
    Last Post: 06-24-2006, 07:54 AM
  3. Key for Seth Thomas no. 89 movement
    By Seth Thomas Fan in forum Clocks General.
    Last Post: 03-31-2006, 12:07 PM
  4. Seth Thomas Chime information needed
    By Tom Kloss in forum Clocks General.
    Last Post: 04-04-2005, 07:01 AM
  5. Seth Thomas chime regulation 2/2 a second imagine
    By luc1963 in forum Clock Repair
    Last Post: 03-29-2004, 11:17 PM
