Results 1 to 7 of 7
Thread: Bushing inside of a bushing & feather question
    Ray Snead Guest
    Default Bushing inside of a bushing & feather question
    I am working on an Ingraham 8 day movement with a front escape. The movment is marked 12 on the left side of the front but there is no mark on the right. Haven't seen this before but I digress.
    The back of the fourth wheel of the time train is loose by around 20% of the thickness of the pivot. I've found this pivot to be especially sensitive so I'll always rebush it when I take the clock apart for cleaning if there is any play there at all. In this case, the pivot has been bushed before with a bushing that is 4MM thick! This is over twice the diameter of a KWM replacement for this pivot. What is the correct solution for this problem? I've tried to get a decent picture that shows the bushing to be ~ 5mm across.
    http://static.flickr.com/79/229515052_3d44ca8779.jpg
    Second question. The pendulum suspension of this clock seems to have been altered. There is only 1/4" of spring between the chops and the end of the pendulum rod. The pendulum spring is just less than half the length of my standard replacements. I am wondering if the spring may have broken and someone just redrilled and reattached it. There is plenty of clearance below. How do you go about finding a close aproximate length to start a new pendulum suspension?
    I've also attached a better picture of the feather. I looks like it slipped up a hair as I was trying to get the picture but you can still see how short it is.
    http://static.flickr.com/68/229517990_2be0b5c155.jpg
    Thanks in advance.
    Ray Snead Guest
    Thanks in advance.
    Dec 2001
    Mountain Top, PA
    1,127
    usa  us pennsylvania
    Hi Ray. First, verify the large bushing does position the wheel properly...meaning it is perpendicular to the plates in all directions. Yes, If I had to rebush a 4mm diameter bushing which is tight in the plate, I would attempt to palce a bushing within it. The KWM #3 reamer will cut a 2.68mm diameter hole, so that doesn't leave a lot on the sides. If a bush inside a bush fails, you'll have to either make one or find a standard that will work for you.
    Concerning the suspension rod, just get a replacement. Keep a small supply on hand because this is a regularly replaced item.
    Bill
    Bill...
    Member Chapter 1
    Apr 2004
    Mesquite, TX
    8,848
    usa  us texas
    NAWCC
    Tryin' to figure out the purpose of the split post below the chops. Looks to me like regulation begins at the split post and not the chops.
    Does the pendulum bob have a regulating nut? Can you achieve regulation as it is? If so, the current one is just fine.
    If you cannot achieve regulation - install a feather of length that will.
    Oct 2005
    19,637
    usa  us iowa
    NAWCC
    I recently had a case like yours - a large bushing. When reaming it for the new bushing, the thing screwed itself out of the movement - yep, one of those "replace the bushing without ever taking the movement apart" screw in things. I kept it, and bushed inside it, but that may be what you have too. What a thing to do to a clock!
  6. #6
    Dec 2003
    West Yorkshire, England
    9,813
    england  uk yorkshire
    Ray
    (1) Just make a larger bush to fit the big hole
    (2) If it is within rate, OK, if not, take a close look at wear marks caused by the crutch on the pendulum rod.
    Mike - banned member of the throwaway society.
  7. #7
    Nov 2001
    South Easton, MA
    2,230
    usa  us massachusetts
    I just had the same bushing issue last night. I'm working on a parts movement that I bought and decided to fix for future installation. Someone used those damned screw in bushings as well. They stuck out of the plates about a quarter of an inch! I'm working on a miniature Waterbury used in china clocks.
    I removed the old bushings and found the closest size bushing to the threaded hole. I made sure it was a bit oversized and then reamed the hole out. I inserted the new bushing and tapped it front and back with a ball peen hammer to make sure it was secure (most of the marks would ream away in step 2.)
    I then found the proper bushing in my set and reamed the first bushing carefully so as not to disrupt it. I popped in the second one and was good to go!
  1. Replies: 3
    Last Post: 03-02-2010, 11:41 PM
  2. What is the Rule for type of plain bushing?
    By bchaps in forum Watch Repair
    Last Post: 06-06-2007, 07:48 AM
  3. To bush or not to bush?
    By BVClocks in forum Clock Repair
    Last Post: 06-08-2006, 11:35 AM
  4. A couple of American clock movement questions
    By leeinv66 in forum Clock Repair
    Last Post: 05-21-2006, 06:40 PM
  5. A Word of Thanks and a Question About Pocket Watches of Civil War Leaders
    By Phil Stover in forum American Pocket Watches
    Last Post: 10-23-2002, 10:27 AM
