NOTICE Notice: This is an old thread. The last post was 1287 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Default Sessions Mantle Clock Westminster Identification
    From what I've read, Sessions made a Westminster 416 WC and Chime C. The stamp on mine reads Westminster #1. Does it fall under one of the models mentioned, or is it its own model?
    There is another stamp that reads 28 10; was this a manufacture date of October 1928? Sorry, I'm new.
    Thank you for your time.
    Nov 2002
    39,095
    Default Re: Sessions Mantle Clock Westminster Identification (By: teknikks)
    Hi, Teknikks, welcome to the message board. Tran Duy Ly's Sessions book shows the Westminster # 1 from a 1927 catalog picture. Yes, 28 10 would be the date of manufacture, October 1928.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Default Re: Sessions Mantle Clock Westminster Identification (By: harold bain)
    Hello, thanks for the reply and info. Would the book you mentioned be a good source of info for this model?
    Nov 2002
    39,095
    There really isn't much information there, just it's length and height, with a catalog picture, and "Genuine Mahogany case, 6 inch silver dial with raised gold numerals and gold plated sash with convex glass". The book would only be useful if you plan on buying more Sessions clocks.
    When I Google this model, there aren't many pertinent results. So I really appreciate your help; thanks again.
  6. #6
    Nov 2002
    39,095
    Perhaps if you post some pictures of your complete clock, the next google searcher will at least see yours.
  7. #7
    Here is more of what it looks like overall; exactly the description you provided. It has some behavioral issues; should I ask about that in the Clock Repair section or maybe the Hints section? Thanks again.
  1. Sessions Mantle Clock or Shelf clock
    By owen.or in forum Clocks General.
    Last Post: 06-06-2005, 05:36 AM
  2. help id sessions mantle clock
    By frank24 in forum Clocks General.
    Last Post: 03-21-2005, 05:28 AM
  3. Sessions Mantle clock ID
    By cenywtyl in forum Clocks General.
    Last Post: 11-09-2004, 12:52 PM
  4. Sessions Mantle Clock Key Size (Double End)
    By Robert Sweet in forum Clock Repair
    Last Post: 05-07-2004, 08:41 PM
  5. Session Mantle Clock - or is it?
    By Sherry Arnold in forum Clocks General.
    Last Post: 07-19-2003, 03:20 PM
