NOTICE Notice: This is an old thread. The last post was 1390 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 1 of 1
    Registered User Noel Poirier's Avatar
    Jul 2007
    Columbia, Pennsylvania
    97
    Default August/September Object - Strasser & Rohde Regulator
    Regulator, c. 1898, Strasser and Rohde. Silvered dial reads, ”Auxiliary Clock.” Weight driven with three jar mercury pendulum. Pinwheel escapement. time only, sweep seconds hand. Oval glass window at bottom of black painted metal case. The clock will be featured in a major multi volume book on German Precision Pendulum Clocks, including a chapter on Strasser & Rohde. The author's research found a 1900 article in a German clockmakers journal describing (and illustrating) the Strasser & Rohde clock in the newly inaugurated Philadelphia City Hall.
ID:	187628   Click image for larger version.
ID:	187629   Click image for larger version.
ID:	187630   Click image for larger version.
ID:	187631   Click image for larger version.
    Noel B. Poirier
    National Watch & Clock Museum
  1. August's Object - Abraham Louis Breguet Pocket Watch
    By Noel Poirier in forum National Watch and Clock Museum
    Last Post: 08-01-2012, 07:21 AM
  2. August's Object - Circa 1800 Rivers & Son Pocket Watch
    Last Post: 08-08-2011, 06:02 AM
  3. August's Object - Terry Clock Company Novelty Clock
    Last Post: 08-05-2010, 09:11 AM
  4. December 2009. Strasser and Rohde. Precision Regulator
    By CET MIH in forum Musée international d'horlogerie Centre d'étude Institut l'Homme et le Temps
    Last Post: 01-29-2010, 12:48 AM
  5. August's Object - Soap Hollow Tall Case Clock
    Last Post: 07-28-2009, 08:26 AM
