NOTICE Notice: This is an old thread. The last post was 1363 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Hermle 340-020
  1. #16
    Default Re: Hermle 340-020 (By: harold bain)
    Could be the fork out of position. They are fussy about where they interact with the wheel. They have to be right on the edge of the flat areas and the fork. The also need to be straight and parallel to the floor.
  2. #17
    Im going to clean the balance tonight and I will post any changes. thanks
  3. #18
    Registered User Earl Stedman's Avatar
    Jun 2010
    North Stonington, Ct.
    425
    Default Re: Hermle 340-020 (By: shutterbug)
    I too believe it's a power problem. I'm sure you feel you've done a good job on the bushings and they may be ok. If you add power to the 2nd with your finger nail and the balance jumps to life it's probably not the balance.
  1. Hermle 340-020
    By Term in forum Clock Repair
    Last Post: 02-12-2006, 05:51 AM
  2. Hermle 340-020 Balance Wheel Adjustment.
    By Don Farr in forum Clock Repair
    Last Post: 11-27-2005, 05:17 AM
  3. how to regulate time on Hermle 340-020
    By Donald P Bellamy in forum Clock Repair
    Last Post: 08-28-2005, 03:37 AM
  4. setting the beat on a hermle 340-020 movement
    By BILLIE RAY KIRKLAND in forum Clock Repair
    Last Post: 06-09-2005, 10:20 AM
  5. Hermle 340-020 Chime Question.
    By Robert M. in forum Clock Repair
    Last Post: 05-12-2005, 02:05 AM
